Hey guys,
I'm very new to the forums and i was just wondering if someone could point me in the right direction of what coilovers/springs to get for my R34? Around western Sydney area.
I want it just to look nice. Not too low though....
Edited by 34-GOKU
https://www.sau.com.au/forums/topic/450956-lowering-my-r34-gt-t/
Much has already bee written in this very forum on that topic.
A little more information provided in your post might help (as in.....what's in the car right now, so people know whether modification makes more sense than replacement, etc etc). Or, you could do some searching and reading and probably find the answer yourself.
I have myself used ksports and tien super streets.
Ksports offer much more adjustment (can go REALLY REALLY low, like chassis on the ground low) and fronts are slightly camber adjustable, but they also felt very hard and would be a good track option, but as a daily at the time, was not functional - you will feel everything on the road.
I now have tien SS. No where near as much height adjustment (I have them set as low as possible, and it will only lower by about ~30mm or so) and no camber adjustment, but on the "hardest" spring setting, they are still very soft and perform well for street use (now just a weekender, but have taken it on a skidpan and felt very nice)
Below is the fronts on lowest setting, rears raised by around 20mm.
BC Racing coilovers are an affordable and proven entry level setup. No point in lowering the springs only, your stock shocks will not last. My rear shocks started leaking in just a few months with King Springs.
Also keep in mind that if you do any significant lowering (over about an inch or so) you'll need to start putting in adjustable arms to get enough adjustment in order to correct the suspension geometry. These things tend to escalate... Alternatively you can just run big neg camber and ignore the handling/tyre wear issues like every other lowered car on the road ;)
Above is correct. Front and rear camber arms set me back $120 and $100 respectively, fairly easy to install but bolts will more than likely be rusted/seized and will be super tight to undo. But still I did myself. Plus another $70 for a wheel allignment. Just factor that in because you will destroy your tyres quick, and a new set will cost far more than a decent set of arms.
  • Like 1
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
