Going by your details as posted above Merli, unless you're talking about drag racing that drop between 1st and 2nd is pretty much irrelevant.
If talking track, 2750 between 2nd and 3rd is a much smaller powerband and even that would only be used at a tight track like Wakefield.
A consideration maybe?
I wish I knew what my ratios were.
:thumbsup:
  • Replies 53
:thumbsup:
Well................... not really :D :D
Are you saying that you only use 5750-8500 rpm whilst driving on the track? Often it's not feasible to change down a gear to keep it in that rev range...
Example:
A tight corner that should be taken in 3rd gear at about 5000 rpm can't be taken in 2nd gear, as that would equate to 7500rpm in 2nd gear (with R33 GTR gearing). You'd actually lose time in the extra two gear changes needed to use 2nd gear into and out of that corner, and you'd only be in 2nd gear for about 0.5 seconds as it revs from 7500-8500rpm anyway.... Make sense?
In reality, you'd be aiming to have a strong 4500-8500rpm range around the track...
Oops, sorry mate...
Here are the gear ratios for the R33 GTS-t Auto box... The R34 Tiptronic is just an automatic gearbox, so I assume it would be the same ratios as the R33 Auto?
1st - 2.785
2nd - 1.545
3rd - 1.000
4th - 0.694
Final Drive - Dunno, probably 4.111
:cheers:
lol, I have an R34 RB25DET that I'm swapping into my 89 240sx SOOO i found the gear ratios for the GT-T and got the answers..... assuming your car is manual transmission
Engine speeds in top gear:-
30 MPH = 977 RPM 40 MPH = 1303 RPM 50 MPH = 1629 RPM 60 MPH = 1955 RPM
70 MPH = 2280 RPM 80 MPH = 2606 RPM 90 MPH = 2932 RPM 100 MPH = 3258 RPM
Top Speed in 1 gear = 37.574 MPH
And changes into 2 gear at 4000 RPM dropping 2800 RPM
Top Speed in 2 gear = 63.876 MPH
And changes into 3 gear at 4338 RPM dropping 2462 RPM
Top Speed in 3 gear = 100.120 MPH
And changes into 4 gear at 5015 RPM dropping 1785 RPM
Top Speed in 4 gear = 135.763 MPH
And changes into 5 gear at 5181 RPM dropping 1619 RPM
Top Speed in 5 gear = 178.176 MPH
And changes into 6 gear at 5804 RPM dropping 996 RPM
Top Speed in 6 gear = 208.746 MPH
oh yeah, ignore the 6th gear (obviously)
Well................... not really :):rofl:
Example:
Shoot Merli, you really have got it :cheers:
  • 1 month later...
That seems simple enough... Cheers!
But after a bit of simple maths, I've worked out the revs drop for each gearchange for an R33 GTR :P
Gear Change Rev Drops (rounded for simplicity)
1st-2nd    3410rpm (8500rpm -> 5090rpm)
2nd-3rd    2750rpm (8500rpm -> 5750rpm)
3rd-4th    1970rpm (8500rpm -> 6530rpm)
4th-5th    2110rpm (8500rpm -> 6390rpm)
So R33 GTR owners should be aiming for a powerband between 4500rpm -> redline (taking into account poor drivers holding you up)... Is that right?
Makes sense... I can understand why people consider GT2530s perfect track turbos for the GTR, since that pretty much fits the required powerband prefectly! ;):)
Very interesting, thanks!
Andrew
Try this
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
