Folks, what is the easiest way to get the bolts out of the top mounts of coilovers. The bolts on mine dont have a hex head or allen key, they are simply round. The thread on the bolts is stuffed so I need to remove them and replace with other bolts. Any ideas how I can do that?
Cheers
Amir
https://www.sau.com.au/forums/topic/450994-removing-bolts-from-top-mounts/
Generally if there is no hex key in the top of the shaft there is a small flat section below the top where you can hold a spanner. If not I guess you need to try a rattle gun, and if you don't intend to reuse the coilovers lock a set of vice grips onto the shaft nice and tight.
Don't forget spring compressors before you start.....
Photo please. Duncan is talking about taking the nut of the shock piston (which is how you get it apart) but you said you want to replace them with other bolts, which sounds like you want to replace the piston.... Not making sense to me
Apologies guys, I should have been more clear. Yes I am talking about the studs which stick out of the shock tower. I removed some from my old suspension but these had an alen key head and were easy to move. I found that there is a small thread in the camber plate which they screwed into. Im assuming the ones I'm trying to get off are similar and have a thread in the camber plate/top mount so I dont really want to hammer them through so as not to damage the thread. Will upload photos soon
Cheers
Amir
They are punched/pressed in, in exactly the same way as wheel studs are fitted to hubs.
Put a socket under the stud so the stud can fit through the hole in the socket, sit assembly with the socket on a sturdy bench, whack threaded end of stud with a hammer so its pushed out into the socket.
The whole idea of the socket is to support the camber plate while hitting the stud back out into it.
If you find new studs to knock in and they fit a little too easily, you can go around the camber plate, right next to the stud hole with a center punch, this will shrink the hole a little to make the new stud a tighter fit.
Cheers Peter. But what if the studs actually screw into the plate? As I mentioned before, another set I tried - the studs were screwed in rather than punched/pressed in. If this is the case with these ones then hammering them out will damage the thread in the camber plate. Any ideas?
They won't be screwed in if there's no flats on the head to use to torque them up.
Exactly what he said. If they were screwed in then no need for the mushroom head underneath and there would have been a method to drive them in by a tool.
I highly doublt that they are threaded into a aluminium hat and just hold via some threads in alloy, notice the large flat mushroom head from underneath?
Its so they dont pull through the alloy when tightening the nut.
They are studs just like on wheel hubs.
I have seen a few manufacturers use this method on coilovers and normal struts on OEM assembies, we had one broken on the rear on our GTR, it was snapped off by the previous owner, when looking at it it was a punched in stud, next time i have the rear coilovers out i will be punching it out to replace it.
Support the yellow alloy top from under where the mushroom head of the stud is with a socket that is large enough for the musroom head to fit through as you hammer it down.
You need something tubular like a socket to fit around the stud but not touch it, it must sit against the yellow alloy top to support it and provide room for the stud to pass through.
I managed to get 3 out of 4 studs out. I grinded some of the stud off, hammered it down and finished the rest of with a nail punch. One stud I cut to close to the camber top and I cant hammer it down and the nail punch is simply not doing anything. The stud is sitting flush with the camber top and seems to have welded itself to the camber top from all the hammering etc. Any ideas?
  • Like 1
Heavier hammer with the punch?
This.
Use a solid punch that covers the whole stud face that you cut and use a heavyier hammer so you have some force behind it.
I wouldnt have cut the studs.....
Edit, i just noticed your using a nail punch NOooooo......use a pin punch thats a similar or slightly smaller diameter than your stud.
http://en.wikipedia.org/wiki/Punch_%28tool%29
Edited by GTRPSI
Thanks for the help boys. Finally managed to get them all off by hammering them, punching them through and swearing at them. All that work and when I was looking at one coilover when it was lying on the ground noticed it was slightly bent. So I have to get it to the suspension place and see what they say. Good times
Amir
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
