dyl33 Posted November 22, 2014 Share Posted November 22, 2014 Hello Today I noticed a hairline crack at the base of the radiator filler neck, it trickles a small amount of coolant when driving and for a short while after until the car cools down. it's not losing heaps of coolant but don't want to be driving and have it open up and lose my coolant I'm not going to drive it until it's sorted in case it goes bang big crack. Just looking at advise as to what I should do, Is it worth removing the stock one and taking it to a radiator place and get the top tank replaced? $150-250 Or buy a brand new koyorad oem replacment radiator $250 http://www.ebay.com.au/itm/RADIATOR-NISSAN-SKYLINE-R33-R34-93-2001-MANUAL-VEHICLE-KOYO-RADIATOR-/200449233351?pt=AU_Car_Parts_Accessories&hash=item2eabb491c7 The car is used 99.5% on the street so a big expensive racing radiator would be overkill and unnecessary. And don't want a cheap china alloy one either Anyone been here before what would be the best way to go? Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/ Share on other sites More sharing options...
89CAL Posted November 22, 2014 Share Posted November 22, 2014 Buy a new one. Fix it now and it might just break in another spot later. Get a new alloy radiator now and less likely to have problems in the future. I bought a Greddy radiator when mine split. Best thing I think I could have done Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430541 Share on other sites More sharing options...
niZmO_Man Posted November 22, 2014 Share Posted November 22, 2014 Genuine Nissan. *Edit* Oh yeah, standard is single core yeah? Grab that GReddy one. Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430550 Share on other sites More sharing options...
dyl33 Posted November 22, 2014 Author Share Posted November 22, 2014 Buy a new one. Fix it now and it might just break in another spot later. Get a new alloy radiator now and less likely to have problems in the future. I bought a Greddy radiator when mine split. Best thing I think I could have done Yeah I'll get a new one, not really keen on replacing the top tank idea. I've looked the Blitz 41mm alloy rad and koyo alloy 53mm they are 500-600$ Not sure if it's overkill and a waste of money. Do these fit like oem? Genuine Nissan. What do these cost? Couldn't find anything online not sure if anywhere would have one and be able to have it to me within a week Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430561 Share on other sites More sharing options...
XKLABA Posted November 22, 2014 Share Posted November 22, 2014 This is dodgy as but I had a mazda bravo way way back when and the top tank split the whole lenght, being young and broke I pulled out the aerodite and put a healthy coat over it till I could afford a new one, 4 years later I replaced it cause it looked dodgy not cuss it was leaking 1 Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430573 Share on other sites More sharing options...
dyl33 Posted November 22, 2014 Author Share Posted November 22, 2014 Some would consider that a quality automotive fix Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430578 Share on other sites More sharing options...
KiwiRS4T Posted November 22, 2014 Share Posted November 22, 2014 Solder up the crack or just get a replacement stock radiator from your local shop. It should last another 15 years. I just use stock radiators in my car with the RB30 and it doesn't overheat on track days. Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430580 Share on other sites More sharing options...
GTRPSI Posted November 22, 2014 Share Posted November 22, 2014 This is dodgy as but I had a mazda bravo way way back when and the top tank split the whole lenght, being young and broke I pulled out the aerodite and put a healthy coat over it till I could afford a new one, 4 years later I replaced it cause it looked dodgy not cuss it was leaking Just fixed a Cracked Honda S2000 Gearbox case that cracked around the drain plug in 3 places (told son not to overtighten it 1000 times before putting the plug back in and what does he do?) with JB Weld. I have heard people are also using it on radiators, but i can tell you his gearbox is not leaking and it saved me from pulling the box out and getting it welded back up again. (or replacing the box) Dodgy as hell but it worked, dont know about the next gearbox oil change though...... Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430595 Share on other sites More sharing options...
89CAL Posted November 22, 2014 Share Posted November 22, 2014 The radiator top tank is plastic remember. I was advided against repairing it when mine cracked. Especially if you are happy to just to get a cheaper than Jap brand radiator. Sounds like it will be fine for what you need. If you want to spend some money than the Greddy radiator is great. Fits perfectly and shroud fits on nicely Really up to you but Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430666 Share on other sites More sharing options...
thewayweroll Posted November 22, 2014 Share Posted November 22, 2014 Just for interest there is another quick fix product called"" rapid fix"" ,it is a glue and powder fixes and bonds everything ",got it a Autobarn ,JB is the goods also . Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430676 Share on other sites More sharing options...
dyl33 Posted November 23, 2014 Author Share Posted November 23, 2014 I'm going to replace the radiator hoses to, would it be a good idea to replace the thermostat while I'm there? The radiator top tank is plastic remember. I was advided against repairing it when mine cracked. Especially if you are happy to just to get a cheaper than Jap brand radiator. Sounds like it will be fine for what you need. If you want to spend some money than the Greddy radiator is great. Fits perfectly and shroud fits on nicely Really up to you but The only Greddy radiator I can find online is $1099.!?Would there be any cooling issues with the koyo oe replacment? Anyone used one? Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430701 Share on other sites More sharing options...
dyl33 Posted November 23, 2014 Author Share Posted November 23, 2014 What about these JustJap cooling pro radiators http://justjap.com/engine/cooling/radiators/cooling-pro-alloy-radiator-nissan-skyline-r33-r34-and-stagea-c34-rb25-rb26.html Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430723 Share on other sites More sharing options...
niZmO_Man Posted November 23, 2014 Share Posted November 23, 2014 I'm going to replace the radiator hoses to, would it be a good idea to replace the thermostat while I'm there? The only Greddy radiator I can find online is $1099.!? Would there be any cooling issues with the koyo oe replacment? Anyone used one? If you have the standard clutch fan and shroud (assuming fan works fine), you're better off getting something that can use the shroud. http://www.perfectrun.jp/src/quick/qui_home.php?qui_cb=101&qui_cmd=cg101008_10102&qui_cpb=0&qui_cat[]=sct_502&submit=GO Take your pic, then either buy through there, RHDJapan, Import Monster, Nengun, or Jesse Streeter. Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430747 Share on other sites More sharing options...
XKLABA Posted November 23, 2014 Share Posted November 23, 2014 The radiator top tank is plastic remember. I was advided against repairing it when mine cracked. Especially if you are happy to just to get a cheaper than Jap brand radiator. Sounds like it will be fine for what you need. If you want to spend some money than the Greddy radiator is great. Fits perfectly and shroud fits on nicely Really up to you but The top tank in my Bravo was plastic and it held up for 4 years with aerodite Just looked like arse Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430750 Share on other sites More sharing options...
XKLABA Posted November 23, 2014 Share Posted November 23, 2014 The stock factory radiator is the best one to have for most all uses, my 3ltr R34 still uses the factory radiator and has been to the track with no over heating issues, well for the coolant system anyway Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430758 Share on other sites More sharing options...
dyl33 Posted November 23, 2014 Author Share Posted November 23, 2014 If you have the standard clutch fan and shroud (assuming fan works fine), you're better off getting something that can use the shroud.=sct_502&submit=GO]http://www.perfectrun.jp/src/quick/qui_home.php?qui_cb=101&qui_cmd=cg101008_10102&qui_cpb=0&qui_cat[]=sct_502&submit=GOTake your pic, then either buy through there, RHDJapan, Import Monster, Nengun, or Jesse Streeter.Are these instock in aus or need to be sent from japan? They all say factory air duct cannot be used with this radiator. I'm still using factory airbox is this a problem What about fenix rads http://www.ebay.com.au/itm/Nissan-Skyline-R33-R34-93-02-Heavy-Duty-Alloy-Fenix-Radiator-/171117111768?pt=AU_Car_Parts_Accessories&hash=item27d75fe9d8 they look quality? Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430764 Share on other sites More sharing options...
niZmO_Man Posted November 23, 2014 Share Posted November 23, 2014 Are these instock in aus or need to be sent from japan? They all say factory air duct cannot be used with this radiator. I'm still using factory airbox is this a problem What about fenix rads http://www.ebay.com.au/itm/Nissan-Skyline-R33-R34-93-02-Heavy-Duty-Alloy-Fenix-Radiator-/171117111768?pt=AU_Car_Parts_Accessories&hash=item27d75fe9d8 they look quality? They get shipped from Japan. You should be concerned about the shroud more than the air duct, but if you want to keep the duct, get OEM. Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430941 Share on other sites More sharing options...
dyl33 Posted November 23, 2014 Author Share Posted November 23, 2014 If the air duct can't be used the factory airbox doesn't work. By OEM do you mean genuine nissan or OE replacement like the koyo rad linked earlier? Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7430950 Share on other sites More sharing options...
dyl33 Posted November 23, 2014 Author Share Posted November 23, 2014 I brought the koyo oe replacement will see how it goes. Should I replace the thermostat while I'm at it or should I not worry? Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7431136 Share on other sites More sharing options...
89CAL Posted November 24, 2014 Share Posted November 24, 2014 Couldnt hurt but may not be necessary. If you get what I mean Link to comment https://www.sau.com.au/forums/topic/450995-radiator-hairline-crack/#findComment-7431341 Share on other sites More sharing options...
