sO ch10 couldnt turn a dime with coverage. i am paying $20 for internet access. $50 for Foxtel Play just to watch tonights race in a hotel! Farking better be a good race!
Cracking good race. Best one I can remember for years. Good to see Williams up there running one two - just all turned to custard when they lost grip levels, their aero appears not to enjoy slower speeds.
So, who to Williams after Bottas goes to Ferrari to replace Kimi? Hulkenberg?????
Well not sure whos engine supply they are taking over?
Lotus? Force India? Williams?
Plus it will obviously be at the cost of the Infiniti sponsorship. Cant imagine Aston Martin has that much money to throw away on sponsorship anyway.
Do I believe it? Not more than the Ferrari engine stories.
Williams are rather sgit at strategy. Lotus in 2013 got it right with Romain...give yourself track positiin and stay in the fight as long as possible. They were 1-2 and simply got stage fright...no matter what Smedley says.
Rain came and mattered for 0 anyway.
Meanwhile Dan sucked...Lotus sucked....but finished MWs book and wasnt a bad read
There was talk of links of Flav to Aston but wont happen. I love how Pat is a clean skin yet Flav is tarnished by Singapore events...even though cleared by FIA of having knowledge...unlike Pat.
Really hope Bottas doesnt go to Fezz...Hulk has done so much kore to deserve to be there...Bottas cant even outqualify Massa at the moment
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
    • Interesting. I've not dived into the cleanliness of the factory CAS. I'm curious if the variations are less of an issue if the OEM sensor were brand new. Optical sensors if they're starting to get dirt and crap into them as they're getting older would definitely cause issues as they age.   It's an interesting point to keep in the back of mind for me though
    • Hmm. Tough one. Without knowing where the conductivity value is supposed to sit, it's hard to know whether a standard DMM set to an available ohms setting would be able to measure anything. Ohms being the inverse of what we're talkng about and probably good enough for the girls I go out with. But if you want to go all hoity toity with a 4 wire rig - go ahead. It can only be more accurate - just in case more accuracy or repeatability turns out to be required. If you're going to the effort, just go chuck the ohm-mage probes into the car's reservoir and see if you can measure anything at all?
