RBR dug the hole ... no doubt.
But i say BS to chassis argument. Look at how RBR had an average chassis at the start of the year. They were allowed to develop which they have done and easily one of the best 3 going at the moment.
Argument could be made that they are the best.
Now engines...all but 3 teams are locked into what they
are given/bought. You could argue Williams get the same gear but this year they have been behind in spec and it is absolutely an engine formula. They tried to fix that issue years ago by freezing engines as a variable to within a few percent.
Now thats its a variable let others catch up just as they can from an aero or susp or brake perspective. Freezing it when it is a huge variable is silly as Renault and Honda teams are forced to sit out a season.
Good on Merc for getting it right...theybdeserve their championships....but imagine if other teams were banned from developing a blown diffuser...or an F-Duct etc....
Engine homologation has, is and always will be, shit.
Kimi is also taking a 5th engine this weekend. It's just not newsworthy for him because he's on half the points of his team mate and not in contention for anything.
Vettel is really only racing Rosberg anyway. Hamiltion's 66 point lead is basically insurmountable with 100 points left on the table in the 4 remaining races. He could DNF two of them with Vettel winning both, and still afford to finish 2nd to Vettel in the other two...
That's an awkward way of saying Vettel would have to win all the remaining races and hope Lewis DNFs at least two of them to even have a sniff! It's never going to happen.
Alonso will be running the new Honda PU all weekend too for the first time - only used in a prac session before. So it will be interesting to see if that goes any better than Jenson's old PU. Apparently this new spec engine introduces their direction for next year.
Edited by hrd-hr30
So will the English prat Palmer get his ass handed to him by Pastor? I doubt it but hope so. i like jim a tad more than James Calado which is really saying they are all tools from different shelves!
How guys like Frijns sit on the bench while...ok. Its the weekend and I should relax
Definitely to invested.. haha.
Let's be honest vettel isn't as big of a tool as homo is.
i dunno about that.....
TBH you have to have the sort of attitude they do to be a world champion. You can say what you want about homo but he can bloody drive.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
