bah, that was just a gentle flop over after bouncing off the tyres. With modern barriers that wouldn't be an issue. Or you could move the wall back. But they'd obviously have more tarmac instead of the gravel trap these days too.
Well, they haven't got an agreement with Renault to supply unbranded engines yet... I imagine Renault would only go ahead with it if they are extremely confident their works PU will be clearly better. Renault engaged Illien at the end of 2014 to help develop their engine. I've read that Renault decided to pursue their own development path rather than use Illien's input...
Have RBR pilfered an ERS guru from another team or something? Otherwise they're probably on a hiding to nothing here.
Edited by hrd-hr30
Building engines probably isn't Renault's problem, it's the associated ERS and "Power Unit" rubbish that teams struggle with.
If the regulations were changed to allow more conventional type engines, fans would enjoy it more and the complexity of design and fabrication would be a lot lower therefore making the units cheaper.
No brainer really.
Edited by Nee-san
Talk is the single cylinder prototype yielded improvements. But as RBR were the ones that paid/introduced Illien they are disputing it is their IP and want to own it. I understand that is largely why Renault are kicking on with their own developments and it seems RBR will use the Renault motor as the basis with the Illien tweaks
Also, the talk is its the atual engine and turbo that is weak with the Renault and the energy recovery majic works well
I wonder if Louise can turn the switch back on next year or whether he will go to sleep now he has 3 x WDCs. Mercedes will have us believe development tweaks have moved the car in Rosbergs favour but surely Louise spending too much time in hotel rooms with C-grade rappers and F grade groupies has more to do with it
Nicole%2BScherzinger%2Bangry%2Bembarrass
I wouldn't be surprised if Hamilton has someone employed to teach him how to act to be liked... The way he answers questions now, initially it's what made me stop hating him as he seemed more humble, but these days it's like he's reading straight from a script..
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
