bah, that was just a gentle flop over after bouncing off the tyres. With modern barriers that wouldn't be an issue. Or you could move the wall back. But they'd obviously have more tarmac instead of the gravel trap these days too.
Well, they haven't got an agreement with Renault to supply unbranded engines yet... I imagine Renault would only go ahead with it if they are extremely confident their works PU will be clearly better. Renault engaged Illien at the end of 2014 to help develop their engine. I've read that Renault decided to pursue their own development path rather than use Illien's input...
Have RBR pilfered an ERS guru from another team or something? Otherwise they're probably on a hiding to nothing here.
Edited by hrd-hr30
Building engines probably isn't Renault's problem, it's the associated ERS and "Power Unit" rubbish that teams struggle with.
If the regulations were changed to allow more conventional type engines, fans would enjoy it more and the complexity of design and fabrication would be a lot lower therefore making the units cheaper.
No brainer really.
Edited by Nee-san
Talk is the single cylinder prototype yielded improvements. But as RBR were the ones that paid/introduced Illien they are disputing it is their IP and want to own it. I understand that is largely why Renault are kicking on with their own developments and it seems RBR will use the Renault motor as the basis with the Illien tweaks
Also, the talk is its the atual engine and turbo that is weak with the Renault and the energy recovery majic works well
I wonder if Louise can turn the switch back on next year or whether he will go to sleep now he has 3 x WDCs. Mercedes will have us believe development tweaks have moved the car in Rosbergs favour but surely Louise spending too much time in hotel rooms with C-grade rappers and F grade groupies has more to do with it
Nicole%2BScherzinger%2Bangry%2Bembarrass
I wouldn't be surprised if Hamilton has someone employed to teach him how to act to be liked... The way he answers questions now, initially it's what made me stop hating him as he seemed more humble, but these days it's like he's reading straight from a script..
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
    • Does power steering have a cooler?   pump is right next to the pump and as I understand r34 hicas is electric so unsure why all that loop going to driver side from the pump where the pump is on passenger side( uk based)  Below seems to replace the entire hosing with this kit https://www.jdmgarageuk.com/jdmgarageuk-power-steering-line-kit-for-rwd-nissan-skyline-r32-r33-r34-silvia-s13-s14-s15.html?gad_source=1&gbraid=0AAAAAqLt7fNuZgXNepjqk8I-qovXgmJCu&gclid=Cj0KCQiA_9u5BhCUARIsABbMSPtHrfTutOf0ROkDV6lb7BQO-dqh2AMpqlyvTw7ncRMMkHjDIICIoA8aAiaZEALw_wcB
    • Cobbers and Bullets were 1 cent each when I was a youngster
