  On 05/03/2015 at 4:03 AM, Roy said:
I offerd them $50 for their budget if they let me crash. I am trying to tell them it would be such a mega, properly epic crash that whatever sponsors they have will love the coverage it will get. it will be iconic.
Renault Would love you!
Pretty sure they always show practice when it's the aus gp..
Getting foxtel installed next week so I won't have to worry, every session live in sweet HD and no Alan Jones or rusty to put up with, no ads and heaps of F1 related shows as well
Its only the Aus GP people. Its the same every year. The races that 10 do show will be with the sky team commentating
Apparently the foxtel broadcast is great. Adding the pack next week prob.
Been some pretty average commentating on ONE of the little bit of coverage ive managed to see. Thet were getting confused that someones time hadnt been registered, finally realised it was because it was an out lap. Saying Nasr's name wrong. Webber is def saving it
Will be interesting to see how the qualifying speed of the cars compares to race speed tomorrow. Last year the rbr cars were quicker in race trim than their qualifying speed showed. Mclaren out the arse though, unless they've still not turned the car up to 100% yet, but I doubt that's the case.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
