I liked webber's subtle insult of maldanado yesterday. They were showing the lotus garage and webber was commenting on how unorganized it was with the tyre blankets coming off at different times and saying how that will alter the tyre temps left to right, but then added "but he probably won't notice it....."
  • Like 1
Its only the Aus GP people. Its the same every year. The races that 10 do show will be with the sky team commentating
Apparently the foxtel broadcast is great. Adding the pack next week prob.
Been some pretty average commentating on ONE of the little bit of coverage ive managed to see. Thet were getting confused that someones time hadnt been registered, finally realised it was because it was an out lap. Saying Nasr's name wrong. Webber is def saving it
My mate told me foxtel still had ads, split screen...Not good enough. They don't do it for the MotoGP..
Which is our own fault for for paying for their service and putting up with their commercials. so In fact we are the dumb kents.
When foxtel first came out did they have advertising?
Nope, they used to have a 6-7 second ad in a show saying what was coming up next etc, never advertising products etc and breaks that are 2-3 minutes long like free to air
The adds are an Aus GP thing. Apparently it's part of the agreement with 10.
I was hoping that was the case. I'll be getting foxtel installed soon so the coverage for the rest of the year better be up to the same standard as the motogp
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
