RBR dug the hole ... no doubt.
But i say BS to chassis argument. Look at how RBR had an average chassis at the start of the year. They were allowed to develop which they have done and easily one of the best 3 going at the moment.
Argument could be made that they are the best.
Now engines...all but 3 teams are locked into what they
are given/bought. You could argue Williams get the same gear but this year they have been behind in spec and it is absolutely an engine formula. They tried to fix that issue years ago by freezing engines as a variable to within a few percent.
Now thats its a variable let others catch up just as they can from an aero or susp or brake perspective. Freezing it when it is a huge variable is silly as Renault and Honda teams are forced to sit out a season.
Good on Merc for getting it right...theybdeserve their championships....but imagine if other teams were banned from developing a blown diffuser...or an F-Duct etc....
Engine homologation has, is and always will be, shit.
Kimi is also taking a 5th engine this weekend. It's just not newsworthy for him because he's on half the points of his team mate and not in contention for anything.
Vettel is really only racing Rosberg anyway. Hamiltion's 66 point lead is basically insurmountable with 100 points left on the table in the 4 remaining races. He could DNF two of them with Vettel winning both, and still afford to finish 2nd to Vettel in the other two...
That's an awkward way of saying Vettel would have to win all the remaining races and hope Lewis DNFs at least two of them to even have a sniff! It's never going to happen.
Alonso will be running the new Honda PU all weekend too for the first time - only used in a prac session before. So it will be interesting to see if that goes any better than Jenson's old PU. Apparently this new spec engine introduces their direction for next year.
Edited by hrd-hr30
So will the English prat Palmer get his ass handed to him by Pastor? I doubt it but hope so. i like jim a tad more than James Calado which is really saying they are all tools from different shelves!
How guys like Frijns sit on the bench while...ok. Its the weekend and I should relax
Definitely to invested.. haha.
Let's be honest vettel isn't as big of a tool as homo is.
i dunno about that.....
TBH you have to have the sort of attitude they do to be a world champion. You can say what you want about homo but he can bloody drive.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
