bah, that was just a gentle flop over after bouncing off the tyres. With modern barriers that wouldn't be an issue. Or you could move the wall back. But they'd obviously have more tarmac instead of the gravel trap these days too.
Well, they haven't got an agreement with Renault to supply unbranded engines yet... I imagine Renault would only go ahead with it if they are extremely confident their works PU will be clearly better. Renault engaged Illien at the end of 2014 to help develop their engine. I've read that Renault decided to pursue their own development path rather than use Illien's input...
Have RBR pilfered an ERS guru from another team or something? Otherwise they're probably on a hiding to nothing here.
Edited by hrd-hr30
Building engines probably isn't Renault's problem, it's the associated ERS and "Power Unit" rubbish that teams struggle with.
If the regulations were changed to allow more conventional type engines, fans would enjoy it more and the complexity of design and fabrication would be a lot lower therefore making the units cheaper.
No brainer really.
Edited by Nee-san
Talk is the single cylinder prototype yielded improvements. But as RBR were the ones that paid/introduced Illien they are disputing it is their IP and want to own it. I understand that is largely why Renault are kicking on with their own developments and it seems RBR will use the Renault motor as the basis with the Illien tweaks
Also, the talk is its the atual engine and turbo that is weak with the Renault and the energy recovery majic works well
I wonder if Louise can turn the switch back on next year or whether he will go to sleep now he has 3 x WDCs. Mercedes will have us believe development tweaks have moved the car in Rosbergs favour but surely Louise spending too much time in hotel rooms with C-grade rappers and F grade groupies has more to do with it
Nicole%2BScherzinger%2Bangry%2Bembarrass
I wouldn't be surprised if Hamilton has someone employed to teach him how to act to be liked... The way he answers questions now, initially it's what made me stop hating him as he seemed more humble, but these days it's like he's reading straight from a script..
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
