Thanks guys. Yeah just a bit dodgy buy got me through 10,000ks no trouble but time to change. Right angle ones dont work? Do I just need one that goes straigh down? Im going to run a few strong rare earth magnets internally to clean up the crap, the filter sock had metal fillings around it!
Im using a 90 degree filter in my 33. Works just fine even to the end of the tank.
really? perhaps the holder puts it off on the right direction...mine was a deatschwerks and the holder made the filter sit the wrong way.
Why would the filter sticking out of the fuel cause an issue, as long as the pump pickup is in the fuel you should be fine. The direction the sock sits should have minimal impact, but of course sitting flat on the bottom of the tank or just above would be best.
45 degree socks are cheap enough for this not to be a problem anyway.
Nope, the gears inside are like oil pump internals, once something hard and incompressible goes through it wear will occur, then you may as well chuck it away.
It's only $100 for a genuine new one... If you buy from the right place of course. ;)
Ok cool, I ran a few litres through a bucket, it pumps fine and sounds like it did when I put it in, the high buzzing sound, but when its hooked up, its a low drone buzz sound when priming and afrs are way too lean everywhere. If it was stuffed it wouldn't pump fine out of car then go to shit in it? Ive changed fuel filter made no difference
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
