Bucket of petrol, pumps fine. Took fuel filter off in engine bay pumps fine so no blockage in line anywhere. Im running a stock regulator
you should check fuel pressure, it might pump but that doesn't mean it will be supplying the right amount of fuel
I don't think you are understanding what you are being told.
Just because the fuel pump will flow a good quantity of fuel with no restriction (ie no back pressure - just an open hose into a bucket) does not mean it will continue to flow a decent amount when you apply back pressure. In fact, even a brand new perfectly good pump flows less with back pressure. But a borked pump could well flow what looks like a decent amount wide open and reduce to a trickle once working against the back pressure of the regulator.
Now consider what you said above about cruising. When cruising the fuel flow rate needed by the engine is low. Further, there is vacuum in the inlet manifold so the required fuel pressure is not real high either. Both of these things could allow the pump to flow enough to keep up with the injectors. But put your foot down and the fuel flow demand goes through the roof. On top of that now you have 10+ psi of pressure in the inlet manifold, instead or 6 or 8 psi of vacuum. So now the back pressure on teh pump has gone up by 16 psi or so. And the poor old thing stops being able to keep up and you lean the f**ker out.
  • Like 2
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
