Contact: PM or 0450 940 107
3" Blitz Nur Spec BNR34 Exhaust stainless: $400
https://lh6.googleusercontent.com/-YgpbLa4lcOI/VG6o8YmARvI/AAAAAAAAAGE/Bkrjjmp_9Vo/w514-h685-no/IMG_20141121_105402%2B%28Custom%29.jpg
Dual Kenwood 12" subs in MDF enclosure $200
https://lh5.googleusercontent.com/-z94k6AI4wm8/VG6o6RDABUI/AAAAAAAAAFs/pVNOGsaaj_k/w816-h612-no/IMG_20141121_105005%2B%28Custom%29.jpg
Stock R34 GTR brake rotors $250
https://lh5.googleusercontent.com/-Nl6ROMMYaiM/VG6o6CfIchI/AAAAAAAAAFk/Q2vhgdMq368/w514-h685-no/IMG_20141121_105147%2B%28Custom%29.jpg
Aeromotive Stealth 340lph in take pump: $180
https://lh6.googleusercontent.com/-adJ8szBQChk/VG6pJh1YQwI/AAAAAAAAAI0/6m0A-Tvy1nI/w816-h612-no/IMG_20141121_113507%2B%28Custom%29.jpg
Innovate motorsports LC1 and Gauge kit. comes with weld on bung. $125
https://lh5.googleusercontent.com/-bG_vav0efeU/VG6pIP3JqII/AAAAAAAAAIo/N49mZO67AaI/w816-h612-no/IMG_20141121_113319%2B%28Custom%29.jpg
RB26 timing cover, suit a spruce up. $20
https://lh3.googleusercontent.com/-Jw0WVyD4c4w/VG6pPfu-RII/AAAAAAAAAKM/eyRE-In6VLY/w816-h612-no/IMG_20141121_114127%2B%28Custom%29.jpg
MINT stock front indicators. suit R33/R34 $30
https://lh4.googleusercontent.com/-NOLVe9sqm9s/VG6pO2QtM1I/AAAAAAAAAKE/Yk5hqyOGypw/w816-h612-no/IMG_20141121_114034%2B%28Custom%29.jpg
MINT side indicators. suit R33 R34 $20
https://lh3.googleusercontent.com/-2fILCKQHX60/VG6pOJFWggI/AAAAAAAAAJ4/W3M_sjCr6RY/w514-h685-no/IMG_20141121_113949%2B%28Custom%29.jpg
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
