Got a little bit done on the holidays.
Got the side mount ducting on. PITA process or fit, attempt fit front bar, mark, remove, trim, repeat. Got it done tho.
CF foglight ducts from Powertrix in the US finish off the front nicely.
Got it all back together and went for a test drive. Returned home to find brake fluid all over my left rear wheel. Caliper seal gone. Swapped caliper out for a spare I had at home and I'll order a seal kit to put through the spare pair and then swap them in.
Also finished relocating my windscreen washer bottle to the boot with the battery. Factory location is right behind the drivers side IC so it had to go. Ended up getting a generic bottle/pump combo due to its small size.
Only issue now is with the mass of water in the line from boot to front and hard braking, the windscreen gets a wash lol
Took it on a cruise on a stinking hot day (up and down a mountain) and everything ran sweet. Temps great, brakes work.
I think it is fairly ready for a tune now. Toshi is coming up later in the month I think :D
Oh, also washed it for the first time since Easter.
Funnily enough I extended the original line. Being a 2+2 tho the stock res is in front of and below the jets. 2+0 has res in rear guard so I am going to chase one down. Aparantly they have a spring and ball valve
  • Like 1
  • 4 weeks later...
Just a bit of an update. Had Toshi up on Friday last week for a tune post piping, IC and ignition 'upgrades'.
We tuned on the street and then too it to a dyno for a quick run. Result was 616hp @ 24.5PSI on BP 98 straight off the bat.
Pretty happy, but on the dyno, maintaining load above 6000rpm the mix was getting leaner and leaner. Running out of fuel. 044 surge tank pump not up to the task so need something bigger.
  • Like 1
  • 3 weeks later...
Another small update.
Turns out that due to an old nistune address file, the VTC was not working during the tune. Long story, but I have since rectified. Comes on alot sooner which is great. The curve would be heaps fatter if I ran it on the dyno again.
Just put in an order for a new loom and an AEM 380L pump to replace the 044 (supposedly a direct replacement as the AEM was designed as an 044 upgrade). Remains to be seen. Sux getting stung by poor AUD tho.
Hopefully I can get the new pump and new loom in before end of March. Shouldn't need much of a re-tune, just a few logs to make sure AFR is fine.
Also have a car PC/touchscreen to go in which was previously (very briefly) installed into Cara's zed. Was too complicated for her so changed it out and has sat ever since. Plan for it is to have nistune and various tunes at my fingertips, as well as data logging/diagnostics in car, without having to carry the laptop around.
Also have some bodywork to be done when my mate Al gets time. Have a stock (modified) vented bonnet from my red zed, and 2 pairs of skirts to be painted (genuine TBO and genuine Greddy). Then I'll decide which ones I like best to be installed.
Keeping mod list current.
ENGINE/EXHAUST
Engine modifications
Block bored 20 thou oversize, decked and o ringed, fitted with forged ACL race pistons and rings
Scat H beam conrods, fitted with ACL race bearings
Crankshaft linished and deflashed oilways
Modified oil pump for greater flow
Heads have received a lot of work with machining, porting and polishing, cc’d, flow tested
1mm oversize Ferrea valves
Competition valve springs
Compression set at 8.5-1.
Inlet manifold has been match ported to the heads and the upper plenum.
JECS 1000cc injectors
Sard fuel pressure regulator and gauge
In tank Sard fuel pump
Custom surge tank and AEM 380L pump fitted underneath the car
Custom fuel cooler,
Braided fuel lines
Motorsports connection fuel filter
Battery has been moved to the boot area sealed in a battery box fitted with an isolation switch
Windscreen washer relocaded to the boot with the battery as it was in the way of the side mount cooler
Selin twin AFM translator
Twin Apexi power air filters
Series two power transistor unit
Spitfire coilpacks
HKS DLI Ignition Amp
Engine earthing kit
Modified crankcase ventilation with catch can
2 x GTX 28/63 ball bearing turbos
BDE (Brett Dempsey Engineering) slimline engine mounts to allow for:
Complete 2.5in intake to turbo to intercooler to throttle body piping upgrade
Massive 2.5 inch in and out side mount intercoolers
Propper ducting for the coolers
Blitz dual SBC controller
(Jim Wolf Technology) JWT 400+ wild Cams
BDE (Brett Dempsy Engineering) modified Intake Cam gears
Tomei adjustable exhaust cam gears
A new set of hydraulic lifters fitted with shims has the motor running nice and quiet
Turbosmart, BOV’s
Ross Racing harmonic balancer
Gates blue belts turning the equipment over.
Engine management is by Nistune
56mm Alloy Radiator
72 plate external oil cooler
BEE*R rev limiter
RARE Final Flag polished throttle cable cover (1 actually have 2 of these)
Exhaust
Custom 5 bolt, divorced dump pipes
AMS exhaust manifolds
3” system through hi flow cats, and pair of Varex adjustable Mufflers
DRIVELINE
UAS six button single plate clutch
X-Treme chrome molly lightened flywheel
Chrome molly one piece tailshaft.
Richmond leader diff gears of 4.11 ratio
SUSPENSION
Bilstein PSS9’s coilovers
Powertrix front upper control arms
Powertrix front lower tension rods
Tune Agent rear camber
Tune Agent traction arms
Energy suspension bushings all round
Nissan front strut brace, one of only two in Australia
UAS HICAS lock out
BRAKES
Front,Stop Tech ST-40 calipers big brake kit
332 mm slotted, curved vein rotors
Braided stainless brake lines
Ferodo 2500 pads
Rear, Reliance Edge 297mm slotted rotors
Ferodo pads
Stone shields have been removed and tubular ducting has been fitted for extra cooling
WHEELS and TYRES
18x9 and 18x10 Gram Lights 57F-Pro
245/265 Achillies 123
Also available is a pair of stock 16” wheels fitted with Mickey Thompson ET street radials for those nights at the drag strip
EXTERIOR
2000 model urethane front bar
Powertrix Carbon foglight ducts
2000 rear tail lights
Modified rear center panel with light up '300ZX'
UAS fiberglass vented bonnet
Modified nose panel
UAS rear wing
UAS enclosed rear bar fitted with Perspex diffusers.
Ab-flug Areo mirrors
Custom made Miracle Zed Motors vented air guides for improved cooling to the radiator.
A HID headlights
INTERIOR
Recaro SR3 driver and passenger seats on Z32 recaro rails
Stock gauges have been replaced with el panels giving various shades of blue
Defi triple set, oil, water temp and pressure
Pivot boost gauge
Apexi turbo timer
Twin AEM wideband AFR gauges
Boarder racing gauge hood
Kenwood head unit with four kenwood 5” speakers
Terrano chrome door handles
Leather 300zx logo handbrake boot
Leather 300zx logo shift boot
2000 model gear knob
Leather trimmed doorcards, glovebox, center console etc
616hp @ 24PSI on BP 98 (cause E85 is cheating).
Edited by MagicMikeZ32
  • 3 months later...
This thread is definitely lacking in the images department. :)
FINE! Haven't had a chance to do anything the last few months, with a 9week old ;)
Pics are from a downshift thing in late March from memory.
  • Like 2
Yeah I am a fan :) Good quality, super light (18x10's are about 9kgs), and correct offsets for big rubber. A mate recently put 305's on the rear of his zed with same width and offsets. Front could do with a little less offset tho.
  • Like 1
  • 3 months later...
Ok so I haven't done a god dam thing to this car. Actually that's a lie I did chuck the new loom in.
Did buy an OS Giken twin plate the other week. It will go in over the next couple of weeks. Engine coming out to replace exhaust mani gaskets anyway so clutch upgrade while it's out. Nothing wrong with the current clutch at current power, but I will be doing e85 upgrades also which the existing clutch prob won't like.
Have shitloads to do before Easter Zedfest:
Engine out
Gaskets in
Clutch in
Engine back in
Dash Out to re-install air con
Car Pc
Dash back in
ECU upgrade
Fuel System upgrade/overhaul
Tune
Bonnet and Skirts painted/installed
Also need to finish off Cara's zed before Easter too :(
In car stuff updated (mods and retrim of sub boxes and create an amp cover)
Air Con compressor replacement (started this on Sat)
Re-retrim of some interrior panels
Fix a terrible power steering leak
Think that's about it. #f*kinh8zeds
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
