New water pump from Nissan
Paid out the ass, but wanted genuine.
Decided to take the head off to check the head gasket and replace it. Also it would make getting the manifold studs out a lot easier.
Head gasket was in good condition, and the head seems to look alright also. Cut my hand open getting the head studs off.. slipped and gashed my hand on the firewall.. -.-
The head is now off, and i plan to put the new intake and exhaust studs in, assemble the plenum, fuel rail, etc onto head before re-installing it onto the block with a set off new head bolts (as they are TTY so I'm told).
Bought a few more things.. VHT paint for the throttle body, plenum, rocker cover, ryco fuel and oil filters, new extractors-to-cat gasket, intake studs etc..
Also have retaped the motor loom so it's all freshened up.
VHT wrinkle paint.
Starting to slowly wrinkle.. :)
Now to go over it with a couple of coats of VHT engine enamel (blue).
Finished product. Turned out quite decent for my first time using wrinkle paint.
Started cleaning and prepping the plenum
Before:
After (still wet):
Actually wrinkled very well, will have more pics in the near future.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
