Hi ppls
In your experience, would there be a lot of diference between the following (Assume the Cat is a Batmbl big one and the Exhaust is a Fujitsubo Power Getter):
Standard Dump Pipe with Blitz front pipe.
Split Dump Pipe and Blitz Front Pipe.
Batmbl combined Dump and Front.
CESRacing full split Dump and Fron combo with wastegate gases joining rest of exhaust about 4-500 mm down the line.
I'm torn you see.
I have the Standard Dump with Blitz Front, and I'm wondering if its worth the money to upgrade the combination...
All help appreciated.
https://www.sau.com.au/forums/topic/45114-dump-and-front-pipe-combinations/
Guest Robo's
In your situation i would be definately upgrading to a split dump and joining to your Blitz front. Your exhaust can only flow as good as your first restriction and i believe it would be in your stock dump. Even the BATMBL front pipe is bigger than the stock front.
I have the BATMBL dump. but if i could get my hands on a split dump i would love to try it as when the wastegate opens there would have to be some turbelance with the exhaust turbine which doesnt help flow.
Bastard.
I want one.
Wanna do a comparison thing for us....
A dyno run before fitting anything, a dyno run with the cat back, and a dyno run with all the bits.
I'll pay for one run as a service to SAU..........
Or maybe a nice workshop is reading this and would help us out by not charging us four runs............
Anyone?
This is interesting, and I am all for a free flowing exhaust... BUT my GTR with the HKS GT2530's and everything that goes with, makes the same as others with the same mods. However I don't have aftermarket dumps and I'm still using the stock cat, the rest of my exhaust is aftermarket. Yep! I'm still using the standard "big time restrictive dumps"... :confused: well so am I.
There's the argument that:
- split dumps are better because they split the gases
- then you have HKS split which are only 150mm long "similiar to CES splits", but this is apparantly not effecient, and some will say you need the TRUST combined front pipe & split dump where the split meets around 400mm down rather than 150mm like the HKS.
- then you have companies like mines who have a dump with no split just a big muther opening..
- then you my tuners tell me save your dosh because the gain on dumps is very minimal, based on dyno testing.
still :confused: ..hmm so am I ! Didn't mean to throw this at ya. :)
Yeah I'm up in the air about it too.
Looking at the R34 cast dump, it can only be restrictive!
But Hypertech told me that there is very little difference also. Maybe 4 or 5 at the top end.
But surely, response would be better?
I'd really like to see the Boost Curve with diffent combos on......
I'd say on the stock boost you would find little gain with the stock dump, but the response would likely change. At higher boost there is a definite change with the BATMBL style in the midrange and the exhaust note..
I'd sell the expensive engine pipe and probably pay less for the combined dump pipe and come out ahead. They are easy as hell to fit but make sure you use anti-sieze paste on the threads.
In reality, when you look at the turbine outlet and the wastegate outlet diameters I see little need to go split on the standard turbo. There is a definite flow impedance designed into the stock dumps however.
Later down the road I will probably be putting a to4 on and at the moment just have a cat back on a 33gtst. I am in the same sorta boat as bass junky Most cost effective is dump and front in 1 (non split) ie. batmbl or flyn and is CES wank factor for the price (How much did you get urs for Daz) ? I can get a 3inch front pipe cheap but split dumps r still expensive. What do u guys reckon i should go with? Maybe getting a local exhaust shop to have a look and give me a quote on making a split one up. Dandenong exhausts made a nice one for a friends rex.
sorry to hijack thread :(
Hi ppls
I'm torn you see.
What about a HKS dump pipe?
Crazo
That's what I'm talking about.
they sell for over $500 new.
At that price, would be better to sell my front and buy the CES racing one.
Decisions...
Enrico... Ultimate Performance Imports have an R33 HKS Split Dump pipe on their page for $350.
Wont fit an R34, but will fit yours.......
Sorry of rthe hijack but I've got a custom stainless split dump pipe for sale if anyone's interested. Was only used for a few months before an engine rebuilt and other mods made me change. Asking $250 but open to offers.
Pm me for pics and details.
I'm not fully sure of where it was made because i bought it off INASNT when i bought his turbo at the end of last year. The thread for the dump is still here but the dump is not as shiney now due to use, still the same part tho in good condition tho.
http://www.skylinesaustralia.com/forums/sh...light=dump+pipe
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
