8 hours ago, ErinH said:
This is mine, had it for a little over a year now. Who'd have thought how much of a headache the older evos are! Gotta replace the gearbox in this one soon
Nice!
A mate of mine has a 6 and another a 10. The 10 sees a lot of track and all he ever does is fill up the tank, which makes (not so) secretly wish I had bought an Evo instead of a GTT. But I'm sure the grass is always greener...
6 hours ago, Hadouken said:
Correct.
I've got a breakdown of the difference between the 2 here
http://www.sau.com.au/forums/index.php?/topic/378971-The-Build-Of-The-Beast
I had a quick read. Looks interesting man. I saw you were looking to get the car tuned haha, noticed some misguided info on that thread on evo's having weak rods. this was only true on the evo 7 where it spits out a rod at 220awkw, That being said my evo 7 is at 250awkw with 470nm of torque stock turbo stock motor and still going strong :P Luck of the draw when it comes to 7s. 9s on the other hand, they go strong, well above 300awkw.
A few guys i know run a bp71 turbo with e85 on stock evo 8s and 9s. A BP71 turbo + e85 gets you to 330awkw pretty easily and safely on a 8 or 9. Ported stock 9 turbo + e85 can get you close to 300awkw, with the added responsiveness of the mivec it will be killer. Low 11 second car. This is all on a stock long block, no forging.
Ooo also forgot to mention the JDM 9 ecu supports flat foot shifting, launch control and anti-lag, so if you have the jdm 9 you might notice the antilag setup on the exhaust manifold :P
Edited by Deza3000
A bloke I work with has an evo x. Was pushing close to 300 awkw on e85 on standard setup. It ended up throwing a rod. So, even the 4B11 does have rod issues at high torque/hp. In saying all that, he used to drive it like it was stolen. To wrap this up, evo's are bloody amazing but just like everything there is some limits that need to be worked around. I have heard of guys limiting torque to reduce the strain on the rods.
  • Like 1
Oh yea i agree, depending on how you drive it and the life its had it will make it weaker. Was your mates evo X a DSG? If so id assume those rapid shifts might incur some torque load on the motor considering the car is never off boost. The way the turbo comes on boost and the how wild the tune is can also determine the longevity of the motor, hence why bp71 is a popular choice (as well as fp's). That being said, lots of R&D has gone into making 300awkw reliable on stock block evos. Lots of forums in uk and us on people running 400+whp on their evos, some even running 500whp - though this is surley going to reduce engine life.
http://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/391588-hp-estimate-what-will-stock-9-block-hold-safely.html
But yea you're right, it might be all in the tune, as you said limiting torque to prevent rod failure.
  • 4 months later...
  • 1 year later...
  • 6 months later...
  • 2 years later...
  • 1 year later...
On 22/04/2022 at 10:49 PM, niZmO_Man said:
Don't drive it too much, will be $100k soon
Lol.
Needs paint.
Tried selling recently, kept getting offers for 25k
Had 35k as price.
Similar with good paint were 45k.
Paint is approx 10k.
So, I figured, 45-10=35.
Apparently not.
People kept saying 35-10 for paint, so 25.
We will see what happens down the track.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
