Hey guys, so my r32 boosts fine up until just before 5000rpm and then I kinda just dies off and only gains revs quite slowly. It's as if it's kinda staving for fuel as it'll sometimes splutter a tiny bit like not bad but it does every now and again. I'm leaning towards fuel pump and it takes awhile to start in the morning when it first gets started like it'll fire and then stall unless I rev it up. It used to pull so much harder when I first purchasing the car around a year ago. All is pretty standard, rb25 turbo, front mount splitfire coils and that's about it. Thanks in advance!
https://www.sau.com.au/forums/topic/451182-rb20det-dying-off-at-5000rpm/
If you think its a gasket, get a hose or piece of flexible pipe and put one end to your ear and with the other end scan the outsides of the manifolds. If there is a leak you will be able to hear it.
Of course the car needs to be running to do this.
Other basic things to check are:
Fuel filter
Fouled plugs (spluttering) - also check spark plug gap if you have feeler gauges
Fuel pump - as mentioned
Wouldn't hurt to do a compression test. Engine could just be tired in general.
Without tuning, the rb20det engine torque curve starts decreasing at around 5500-5700rpm anyway. Unless you're in 1st or 2nd it doesn't really pull hard past those figures.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
