Hey guys,
So i'm planning on purchasing an oil filter relocation kit. I have seen the trust/greddy ones going around but am unsure on the quality of them as the fittings they use on the hoses are hose clamp fittings as apposed to JIC (better seal, and have been told to use if i can) and the plate/adapter that goes where your oil filter is, screws on like a filter and i have heard these apparently leak?. Just after any experiences you guys have had with these kits or any recomendations on any particular kits.
I have found this one, not sure on it tho...
http://www.tunershop.fr/tunershop/product_info.php/manufacturers_id/224/products_id/13115/osCsid/3u51mhpj6u9vjk25d4nsjui903
Heres the greddy kit im refering to.
http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=1357&category_id=92&keyword=greddy&option=com_virtuemart&Itemid=53
any help would be appreciated! :)
https://www.sau.com.au/forums/topic/451185-oil-filter-relocation-kit-r34-gtt/
Oh yeh. So I looked at the universal one u posted. That's the exact one I got but came with the cooler.
I had leaks and when I rung 999 automotive
They sent out a whole new kit for free.
So they must be cheap. Anyway. That one leaked too. So ended up getting speed flow fittings. Cost me heaps.
And the filter is a honda filter. Z79a So throw any spare skyline ones u might have away
One more thing., more chances of leaks. Hoses everywhere, they look crappy orange. Hard to mount in the correct position. I'm not sure with yours but my oil pressure gauge had to be mounted there aswell and that was a cross threaded head ache. Re tap- leaking nightmare.
I hope I've talked you out of it.
When do you change your oil? 6 months?..
Get over it and leave it. I will take you 6 months to sort all the added problems.
Mount a oil cooler if your gonna touch anything around there.
Cheers for the reply/advice! Appreciate it heaps and Yeh I'm probably going to steer clear of that one ;) what about the greddy / trust ones? Yeh I do change oil frequently.. But was interested in relocating filter to suit mods I plan on doing in the near future (forward facing plenum etc) obviously that'll affect the accessability of the filter.
Also I just recently purchased some new gauges which included oil temp and oil pressure and basically when I come to install them I figured I'll need to install them into a sandwich plate anyways so may aswell do it all together if that makes sense?
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
