Hi guys,
Moving overseas so the Ceddy needs to go, This car has been meticulously maintained and is a one of a kind in Aus (seriously... this is the only Y32 in Aus!).
It will truly be missed once it moves on but sadly it needs to go.
Car: 1994 Nissan Cedric Gran Tourismo SV
Engine: VG30DE non-turbo V6 3.0L (similar to the non-turbo 300ZX) <-- Yes this is P-plate legal
Drivetrain: RWD 5spd Automatic with an LSD apparently, though i am not sure if thats true
Interior: Leather seats (redone with Clazzio seat covers), climate control, cruise control, sunroof, electric windows, drivers seat etc
114,000kms
Price: $13,000
Pics:
Many of you might have seen pics on here and on my build thread, but for those who missed it...
Note those pics are with the temporary bumper, and without the sideskirts/rear lip
Also the height is probably close to the lowest you can comfortably go with the coilovers.
Rears are pretty much on the bumpstops, fronts near the bottom of the adjustment thread. For everyday driving i usually have it around this height (note also the proper bumper, sideskirts/rear lip have been installed here):
That gets into most places you need to go, and only scrapes on big speedhumps
Modifications:
Suspension: JIC SF-1 Coilovers, Pillowball camber arms, toe arms, front caster arms
Brakes: 300ZX 4-pot calipers and rotors up front
Wheels: Work Schwert 19x9 and 19x10 in step lip and custom ordered finish (white on the right side, white/polish on the left side)
Exterior:
Baremetal respray in Mazda Crystal White Pearl; everything except the engine bay (inside of hood and trunk painted gloss black). Roof done in toyota Jet black.
Mirror indicators, custom red-clear taillights, HID projector retrofit with Audi projectors 55w Morimoto hids, crystal corner indicators.
Ultra rare full factory lip kit inc chrome front lip, side skirts and rear lip.
Cat back exhaust.
Interior: Clazzio seat covers, chrome drink holders, Altezza Disegno steering wheel with CF look and diamantes. 6.5" DVD/headunit, reversing camera in number plate garnish connected to 6" LCD mirror/monitor (automatically switches on in reverse). Xbox gaming console flush mounted in boot and configured as a media player with XBMC and a 200gb HDD
There are probably other things which i cant recall right now, but you might find after a few months of owning it
https://www.sau.com.au/forums/topic/451220-syd-y32-nissan-cedric-vip32y/
  • 1 year later...
Glad to hear it's still around, have to keep my eye out, don't see many of these in Adelaide for sale unfortunately
As far as i know theres only 2-3 in Aus. Might as well find something to import, no point waiting for one to pop up for sale.
  • Like 1
  • 4 weeks later...
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
