Hi all,
I had my V35 coupe parked on the side of the road today, and when I started it up to drive off, I was met by an extremely loud screeching noise when I turned the wheel to the right and started to drive. It seems to be coming from the front, drivers side wheel arch.
After a 4-5 seconds, the squeal stopped. I drove forward for about 20m, then turned right onto another street when it squealed again- this time it was nowhere near as loud or long. I pulled back over and let the car idle for a minute, before taking off. It was only a 10 minute drive home, and it did not make the noise again.
Does anyone know what this could be? A few google searches indicate the power steering may be the culprit.
The power steering fluid is full to where it needs to be. The alignment seems to be fine. For the last few weeks, there has been a light clunk noise coming from the front right suspension (the car has tein coilovers), which I was going to get looked at after christmas. There don't seem to be any leaks from the car either. Usually when I reverse out of the drive, there is a slight buzz noise (presumably due to the EDFC) once I have started driving.
I purchased the car from a specialist importer, and am the first owner of the car in Australia. The car has just ticked over 80k kms (I have dereg papers and import papers etc to confirm this).
If anyone has any ideas, please let me know so I can contact the dealer with at least some knowledge of what the problem could be.
https://www.sau.com.au/forums/topic/451230-squealing-noise/
stone stuck between the brake rotor and caliper or caliper bracket..
Interesting...
I took it for a drive an hour or so ago and it didn't do it.
Hopefully it was just gremlins... I might get my phone ready when I go to work tomorrow and see if it does it again...
https://www.sau.com.au/forums/topic/451230-squealing-noise/#findComment-7434721
I would say old/loose ancillary belts. They aren't expensive to replace, $70 for both from memory, and about 30 mins of your time.
+1. Commonly heard on old bangers but can happen on newer vehicles if the belt has been damaged or is getting dirty.
https://www.sau.com.au/forums/topic/451230-squealing-noise/#findComment-7434816
they should be ok, but these size belts are an 'off the shelf' item, you should be able to buy at just about any auto parts store.
Slipping belts often squeal when starting from cold and get loud when you rev the engine, and often go away after the first minute or so of driving. also can get louder when you put them under load, eg. power steering pump load (turning when not moving or moving slow) or AC compressor. Shouldn't really make much difference if you are turning right or left. and would also come from the front of the car, not the right side wheel arch.
https://www.sau.com.au/forums/topic/451230-squealing-noise/#findComment-7435943
well sort of.. not really in the wheel arch... it is close enough to the front centre of the engine bay that it would sound like it is coming from under the bonnet when you are in the drivers seat.
when I had a faulty fuel damper, it sounded like it was coming from the engine bay, even thought it was the rear right side of the engine.
The sound of a squealing belt would also be quite a bit different to a rock in the calliper. a belt is a screech.. but a rock is more of a metallic scraping sound which is usually a bit modulated with wheel rotation speed.
https://www.sau.com.au/forums/topic/451230-squealing-noise/#findComment-7436027
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
