GTSBoy Posted December 4, 2014 Share Posted December 4, 2014 There's not much conflicting there. The highflow turbo is going to be able to make 225rwkW. The GTR injectors will flow it. He didn't mention what AFM he was using but it is unlikely that it was an RB20 one. ** The only sticking point is the R34 SMIC which I would have thought would be getting bloody hot at that power level. ** It is important to remember that RB20 and RB25 turbo AFMs are supposed to be the same. RB25s are known to be able to get up towards 220rwkW on those AFMs, so it would seem that RB20s should be able to as well. But I was running up against the 5V limit on mine at <180rwkW. It is very important to realise that some people tend to "tune" above the max voltage of their AFM, which can be a bit risky. Not suggesting that SK did, just that you need to know everything about a setup before taking any lessons from it. Have a look at the Hypergear thread for information on what RB20, RB25 and Neo turbo highflows are capable of. If you want a laggy setup that doesn't make enough power to justify itself, then a 25highflow on a 20 would be a reasonable choice. Some people like the sudden boost rush at 4500rpm. I don't. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437487 Share on other sites More sharing options...
Matvei27 Posted December 4, 2014 Author Share Posted December 4, 2014 (edited) If I am understanding you correctly you are basically saying that: 1. RB25 hi-flow is not worth it 2. RB25 standard is not safe b/c ceramic i.e. you are telling me to hi-flow my stock RB20 snail. But for the price to do that ($1500?) should I just buy a HKS 2530 and run it at lower boost levels? Edited December 4, 2014 by Matvei27 Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437545 Share on other sites More sharing options...
GTSBoy Posted December 4, 2014 Share Posted December 4, 2014 RB25 stock, run at 12 psi will be fine. Some risk of it dying, but fine. Don't push it harder than that because now you're spending money on everything else for a turbo that you can't push very hard. RB25 highflow can and will make a lot of power on an RB20 but will be quite laggy. Given you said you don't want lag...... Check the Hypergear thread. Highflow <$AU1000. Check the exchange rate. Sleaze these and other Aussie forums for a blown RB20 turbo that you can buy and get sent to HG. Freight finished product back to US. Spend <$US1500 on a superior product. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437566 Share on other sites More sharing options...
Matvei27 Posted December 5, 2014 Author Share Posted December 5, 2014 (edited) I can get a HKS 2530 kit brand new for $1800 USD though. Doesn't that make $1500 for a RB20 hi-flow kind of a waste? Can I run the 2530 at a low enough boost level? And what boost level are you suggesting I run a RB20 hi-flow at? Edited December 5, 2014 by Matvei27 Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437816 Share on other sites More sharing options...
GTSBoy Posted December 5, 2014 Share Posted December 5, 2014 I said less than $1500. You juggle your impression of the relative value. Only you can make that decision. If going highflow or 2530, there is no point running less than 20 psi. If not going to use the capacity of the turbo, don't bother. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437842 Share on other sites More sharing options...
Matvei27 Posted December 5, 2014 Author Share Posted December 5, 2014 (edited) 20psi definitely wouldn't work with my SMIC as Rekin said he had heatsoak on his ARC unit at 15psi with a 2530. I don't care about the price as much as I care about getting the best option within the limits of my setup. What kind of boost do people run the RB20 hi-flow at? That being said, you could also get a RB25 turbo with a set of Tomei poncams and gears for a similar price to a RB20 hi flow. Couldn't you run the RB25 at 12psi and use the tomei kit to fix the low end so it has the same responsiveness as the stock RB20 unit? Edited December 5, 2014 by Matvei27 Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437863 Share on other sites More sharing options...
Badgaz Posted December 5, 2014 Share Posted December 5, 2014 You want to do all that shit with a smic.... You need your head read. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437874 Share on other sites More sharing options...
GTSBoy Posted December 5, 2014 Share Posted December 5, 2014 Adding cams NEVER makes the bottom end better. Put gears on it if you like. Go for your life. At least they're cheapish, so the very marginal benefit you get from them won't be too much wasted money. What I have said above is very simple. IF you are going to buy a decent turbo capable of running 20 psi and making bulk power, then you proceed to run it at low boost, you have just wasted all that money. If you are going to stay at low boost to keep your SMIC and foglight and aero bumper (and no comment from me on the driving enjoyment to be gained from having those things compared to having more power) then just buy an R33 turbo and be done with it. Upgrade nothing else. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437879 Share on other sites More sharing options...
Matvei27 Posted December 5, 2014 Author Share Posted December 5, 2014 OK then I am going to order a RB25 turbo and will consider adjustable gears only if the lag bothers me enough to warrant the money. I have a new fuel pump but would you recommend changing the injectors or not necessary? Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7437899 Share on other sites More sharing options...
GTSBoy Posted December 5, 2014 Share Posted December 5, 2014 (edited) The injectors and the AFM kind of run to about the same max point, so change one means change the other. EIther or both of those means change engine management too. You really should do the ECU anyway, because you will make a lot better power with a tune instead of allowing the stock ECU to run rich and smokey at 12+ psi of bigger turbo. Edited December 5, 2014 by GTSBoy Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438029 Share on other sites More sharing options...
Matvei27 Posted December 5, 2014 Author Share Posted December 5, 2014 (edited) I have a RB20 power FC already, which was hard to get. I'm thinking if I change the injectors and AFM and upgrade to the ARC side mount instead of the R34 GTT side mount (105mm core vs 80mm core) I should be okay for 12~14psi on the RB25 stock turbo. Sound right? Edited December 5, 2014 by Matvei27 Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438053 Share on other sites More sharing options...
zebra Posted December 5, 2014 Share Posted December 5, 2014 Or...just put a front mount on it buy a 2530 and crank 20 odd psi down its throat Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438054 Share on other sites More sharing options...
Matvei27 Posted December 5, 2014 Author Share Posted December 5, 2014 (edited) Or...just put a front mount on it buy a 2530 and crank 20 odd psi down its throat That's not the point of this thread. Obviously that's one solution. At this point all I want to know is how to get the most out of the RB25 turbo with a side mount. My car is barely legal as it is, the last thing I need is a FMIC telling everyone to pull me over. Edited December 5, 2014 by Matvei27 Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438060 Share on other sites More sharing options...
zebra Posted December 5, 2014 Share Posted December 5, 2014 Well, I'd go the ARC cooler, a 2530 injectors etc, and tune it to the sweet spot where it isnt cooking the air and run WMI as insurance. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438153 Share on other sites More sharing options...
GTSBoy Posted December 5, 2014 Share Posted December 5, 2014 My car is barely legal as it is, the last thing I need is a FMIC telling everyone to pull me over. Ever seen one painted black? No? That's because you can't see them. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438156 Share on other sites More sharing options...
Matvei27 Posted December 6, 2014 Author Share Posted December 6, 2014 (edited) SydneyKid has basically told me that changing my ceramic turbo for another ceramic turbo is a waste of time/money, so I'm now between getting a RB20 hi-flowed or buying a 2530. Opinions? Price is around the same. Which is the better choice for my setup? 1bar or so seems low for the 2530, but might be perfectly fine on the hi-flow RB20? Rekin said he never tried the RB20 hi-flow that he had and just went straight to the 2530 (which heat soaked at 15psi), so my inclination is to just try the RB20 hi-flow and see how it goes. Edited December 6, 2014 by Matvei27 Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438525 Share on other sites More sharing options...
Matvei27 Posted December 7, 2014 Author Share Posted December 7, 2014 I got a RB20 turbo for $100 to hi-flow. It actually isn't even blown. Thanks guys, sorry for all the questions. The Skyline scene in the USA is much younger so less information out here. Link to comment https://www.sau.com.au/forums/topic/451296-rb25det-turbine-on-rb20det-r32-gts-t-with-smic/page/2/#findComment-7438924 Share on other sites More sharing options...
