As a novice, I did a lot of searching and listening to blokes on SAU that are running 350 to 400awkw + and they swear by the Nismo Super Coppermix Twin "Comp Spec" mine had the ( lightweight flywheel kit) , as a DD they say it drives like , close to a standard clutch and rated around 740HP+ if you want to turn the wick up.
If anyone is interested, I am pulling out an "OS Giken Quad Clutch" with about 4000 Klms on it, no track work but a fare few launches :) I was advised to change it as it is too strong and I needed something a bit more forgiving on my standard R34GTR box.
May very well be a dumb question but can you modify the quad plate to run as a twin plate (ie removing the two additional plates)?
How much are you looking for?
Also is it likely to damage anything if I ran a quad on mine?
Cheers
As a general rule (and I think Kat mentioned this) RHD is what is listed with freight.
I've not been charged any additional charges for kit over $1k that I have ordered from that site.
* Also as mentioned IF it is in stock 2-3 weeks. IF it is not can be 2 months.
(The reason I got the Xtreme twin plate was that my clutch was shot and I could not wait 6-8 weeks for the Nismo Comp)
Edited by Sinista32
Cheers
No because the carrier is different
Do you have to add gst to the prices quoted on rhd or is it pay what is listed at the checkout and that's it?
No, that is something our Gov may charge.
But Free trade agreement with Japan is probably why no one has needed to pay duties.
Thanks everyone for their thoughts.
Ended up sourcing a twin plate nismo gmax clutch from a forum member for an absolute steal and john will be fiiting it up next Monday.
From what i've read up on these, they're completely different (inferior/older) than the coppermixes but will be more than what I'm running atm.
Cheers
  • Like 1
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
