Just getting the last bits together to assemble my surge tank that will house a walbro 460 and I'm not sure on a couple of things.
I need to seal the fittings in the lid of the surge tank as I'm not using weld in style fittings.
Has anyone used those red fuel resistant fibre washers with e85? I will need to leave them submerged in the tank.
Also.. what's the go with fuel hose.. read lots and no real definitive answer. What should I buy.
https://www.sau.com.au/forums/topic/451345-fibre-washer-and-fuel-hose-in-e85/
The Aeroflow 400 series is apparently ethanol tolerant too, but I have had some perishing issues recently with the outside sheath.
I used copper washers under my bulkhead fittings, I tried teflon washers and they leaked. Alloy washers should work well too.
the SAE standard for biofuels is a minimum of SAE 30r9 ....submersive fuel hose is SAE 30r10. its expensive but good for piece of mind. it has an additional impermiable layer on the inside....don't worry too much about the hose being metal braided unless its in the engine bay where foreign flying objects could cut fuel hose.
Thanks for the info everyone. Exactly what I needed to know.
I'll give the fibre washers a go on the test bench and see how it goes. If not I'll run some copper or alloy. The bulkhead I'm running through the lid is 16.5mm and I could only find copper in 16 or 18mm.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
