I have a couple of R31 to sell. I have moved to New Zealand and have no where to store them anymore. Hoping they will go to a good home and continue where I left off with drifting.
Both cars run sweet but the GTS-X needs a windscreen and a good tidy up. It seems a shame to strip the GTS-X but realistically it will make an excellent donor for the TI which is already set up for drifting.
Im looking at about $2000 for the pair or will sell seperately for the right price. PM me for more info and offers.
1989 R31 TI details:
RB30E
Surge tank and external Walbro fuel pump.
S13 Strut conversion with Tein coilovers
R33 N/A front brakes (stock wheels fit over them)
Manual conversion.
Brass button friction plate.
Mini spool.
Electronic line locker.
Nitros Oxide wet kit. Solenoids removed but lines and brackets still installed.
Pacemaker extractors with 2.5" straight through exhaust.
Heaps of rims.
Heaps of spares.
Much more that I have forgotten.
1989 R31 GTS-X details:
RB20DET
Front mount intercooler.
S13 Strut conversion with 5 stud rotors.
4 pot front brakes
All new suspension.
Sway bars.
Strut braces.
Nissan Patrol pressure plate with brass button friction plate.
Also more that's been forgotten.
PM me for more info, offers, etc
Buyer needs to bring their own 5 stud (nissan stud pattern) wheels for the front of the GTS-X. Not being sold with the 3 spoke that is shown in the photos. Sorry but I have no other 5 stud wheels i can throw on it.
I gotta get rid of these things as soon as possible. Make an offer and I'll probably take it. Otherwise they're going for scrap metal which would be a waste considering the suspension alone is worth over $1500
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
