Hi,
I have a R34 GTT running an apexi power FC computer,
After mentioning that I am going to a top mount Forced performance 3076 turbo I was told I should upgrade to a Haltec Platinum Pro.
E85 is not an option for me so there is no advantage there.
However the 2-stage launch control and flat shifting features of the Haltec interest me.
My boost is currently controlled by the PFC hand controller, but if I got the Haltec I would need to install another form of EBC?
I have also seen the map sensor only supports 1.5 bar of boost?
What advantage would the Haltec offer other than more tuning resolution (32x32 vs PFC 16) and the ability to ditch the Z32 afm
Appreciate any input and discussion
Anything that gets rid of the air flow meter is a step forward
Do not underestimate how much of a big deal no AFM's are.
Also I just upgraded to a haltech in my R34 and I couldn't recommend it more. Yes it can fully control boost if you buy the boost control solenoid and you can buy an external MAP sensor that will measure up to 5 bar (from memory). It also has much better knock control than the PFC
I would definitely recommend it if you're chasing big power, there's more inputs and outputs you can use to watch AFR's, intake and exhaust temp and like a million other things to keep you engine nice and safe
  • Like 1
the turbo itself shouldn't be a reason to ditch the powerfc....and with that turbo you probably won't max out a Z32 Afm. It really depends what your goals with your car are.
the tuning resolution on PFC is 20x20 not 16x16
the newer ECU's do have more features as the others have already mentioned so these should be considered for your future planning, but for what you currently have you don't need to change ECU yet.
I recently switched from PFC to haltech, the car runs the best it ever has,
For me the benefits are no MAF is great, the PFC random cough thing is gone, boost intergration is nice, having a few extra IO points is handy for running others stuff you might add and full data logging for diagnosis
Of course the skills/ability/attention to detail of the tuner will have a big impact on how the car runs.
Boost control will work with your existing solenoid you'll just need wire it up to the haltech and I'd run the external MAP sensor regardless of your desired boost level,I don't really like running a vacuum line back I to the cab
If I was to do it again and wasn't going for flex fuel I'd still ditch the PFC.
All in all the haltec is a good system. Good functions and options. Just be mindful that it has intermittent problems in processing the cas signal which lead to timing variations of up to 20 degrees. Not the only system that does this either. That's why a pfc is always a safe bet if all the extra functions aren't needed.
If you are curious to learn about what your car is doing, and what an ECU can do, and monitor shit and .. really just 'see' more then yeah.
Haltech's stuff is super easy to understand. The fact you can plug right into where the stock ECU is is just gravy.
On a slightly different note. If I wanted to replace a PFC on an RB26 and keep the AFM's what ECU would be recommended?
i don't understand why you'd want to do this? but the plug and play haltec will do it
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
