I had Type Bs in my 34 when I bought it and dialed them in best I could and still wasn't happy with what they did so swapped them out for Type Rs (only cause I couldn't find stock R34 cams for sale at the time) and made same peak power, +/-2-3kws, but came on +/-800rpm sooner
I know why this is but CBF writing it from my phone :(
  • Like 1
I got type b for my 25det neo but haven't installed them yet, somebody told me to go the smaller cams for this reason but majority said the type b's were better, and tomei claim the type b make more peak power and better response than type a
Tomei will tell you what ever it takes to sell you a cam, other people it's the placebo effect of it makes 10kw more up and at idle it goes "wank wank wank" but what most people forget to tell you is it makes 20kw less thru the bottom
But with playing with lift and duration in many set ups, we've (me, Mic, piggaz and others) proved that on low mount turbos the bigger duration cams make everything worse
An easy way to look at it is to increase response people increase compression and larger duration cams reduce compression
As a side note I thought so much of my type b pon cams I gave them away
I am talkin on a 25 neo, where there is no 'type r' available. Stock cam is intake 236 8.4mm exhaust 232 6.9 mm and the type b is 260 9.15 intake and exhaust.
But do tomei measure from base lobe or from .050" lift?
Although I am going top mount forced performance 3076 it is still not a large turbo, perhaps I should go with type a with 252 degree and still 9.15mm lift, it is still a considerable amount larger than factory
The type b on the neo engines Is good.
Type b on rb26 not so good.
260 is the advertised duration. You can Google tomei cam cards and see the duratiom at 50 (around 222 from my crap memory)
Edited by Ben C34
Cams are cams and work on crank rotation angle, makes no mind what engine they are on
Go the 252s
The Tomei cam duration is takin from lobe contact on to lobe contact off given the correct clearences from bucket
Sort of. Perhaps it's the vct on the neo that makes up for the loss on the rb26.
Vct wins. Neo has vct. Neo wins!
Neo is a sales gimmick and not worth shit on a turbo, add lift to it and then maybe but I'm yet to see a neo match my 32 for power AND response on the same boost and my 32 still runs bush bearing stockers :/
I can not post pics for some reason, will see if I can get someone to post it for me
So much right in that statement.
Just because someone makes something and their marketing says you need it - does not mean you buy it.
For that size of turbo, which really isn't big, stock cams would still be a pretty damn good choice if you needed to spend money elsewhere like:
Brakes / Suspension / Diff / Clutch - starting point of total spend is around 8k.
And if you haven't spent money in those 4 areas - you should be before touching the cams because you'll actually get decent benefits of being able to stop better, actually drive around a corner with the added power and/or actually put said power to the ground. All are critically important, far more so than a few kw here/there on a graph.
