Looking good!! What did you end up changing in the fuel pump relay setup compared to what you were originally doing? I was pretty sure a relay will close with only very small voltage, so im curious as to why that wouldnt work.
Look forward to more updates..
Thanks KD,
I was talking to Scott and he mentioned that the relay wont energize properly on the low power coming from the FPCM so it would be better to use a solid state relay then energize the fuel pump relay with that.
I haven't changed it yet but I'll just keep an eye on it all and see how it goes for now!
Stay tuned, I'll be doing the turbo, clutch and a few other things in the next few days
Keep up the posts man it looking good!
I recently installed the same BOV just running stock boost and there was a noticeable improvement in spool up!
Oh - I didn't realise it would also help with spool! I guess its good for me then too :)
The car is running quite rich which I'm guessing has something to do with the new pump as it ran fine before that so I've ordered a fuel pressure gauge to check
After installing the pump the car was running a bit how do you do.
I looked around and spoke to a few people and they mentioned that the stock fuel regulator could be failing or couldn't be keeping up with the return flow.
I ordered a Nismo FPR to keep the stock look and the a gauge and installed it today.
The car seriously runs a lot better - its practically day and night comparison.
I didn't post pics the other day for some reason but
Nismo FPR
27890D23-EECB-45E3-A361-19BE42926930_zps
Gauge
4DE652A0-D61A-415E-8898-B0ED8CD25C61_zps
Wastegate actuator - I need this because I don't want to be running 20 pound all day every day. I know someone else who installed the same actuator with the same turbo without issues.
5D443786-ED3E-4105-A455-D1BBD549A20B_zps
8C92D760-A07B-44B0-843D-698C65CC7771_zps
15E3D799-A70F-4681-BD82-C85091CE2517_zps
22D5EA12-F462-49A2-A70A-56975ECDF6D2_zps
Extra springs of different pressure. Ideally I'll be putting the 15psi spring in and running low boost at wastegate pressure and full boost between 18 and 20.
B686F775-3459-49AE-BD82-6242634D4E79_zps
Manifold studs - I bought them from a place in QLD if I had realised they would drop ship from GCG I would have picked them up from GCG myself considering these took over 3 weeks to get to me.
A9F39C5F-45C7-40DA-828D-62579338ABC0_zps
I also fitted my Nissan Genuine OEM clutch master cylinder then Ordered my HEL Braided clutch line today, Ordering my clutch kit tomorrow night, Nismo pivot etc.. Then we do the clutch Thursday, Friday, Saturday and Sunday.. ON THE FLOOR WITH NO HOIST :O
Pics and updates to come when we do the clutch then turbo shortly after. Then I'll order the injectors and send it for a tune. Completion date for this work is aimed to be the 20th November.
I caved last night and started ripping shit out of the car.
Starter Motor off
Tailshaft marked
Fluid dropped
Shifter out slave off
All connectors removed from box
Breather off the gearbox
I won't have time to work on it tonight but I'll continue tomorrow night for sure.
Progress pictures to come tomorrow.
Soooooooo. Pulled off the clutch, flywheel etc.
Yesterday when I got the gearbox before removing the above I could see what looked like the lightweight flywheel I just bought.... I was right, already had a lightweight flywheel.
E6B00308-CA92-4E55-8286-00BFE1A03011_zps
42AC3289-1213-488C-8E78-775C6443D6C9_zps
C2212A42-53F4-4C88-8D64-1BD4FB5D9C7F_zps
Some weird sort of thread locker?
EF6D6F53-1CEE-4C77-8AF0-40301E8BAB66_zps
This was the old clutch BTW
7108D577-556E-4571-8C45-09F3464C6A82_zps
97C5A35B-1618-46FF-9A40-A9AF9FD35B78_zps
No stamping of part numbers on it and in all honesty, great condition but it just won't keep the power when the car is done.
Rear main - Struggling to get it out but I'll get to it.
1154A378-778A-44E4-9772-60E3A798B7AB_zps
More pictures eventually. I'm going to work on creating a how to using someone else's instructions with their permission and detailed pictures. In particular the top gearbox bolts which are beyond stupid.
I caved in and went back outside to do more work in this terrible heat.
Before
43F5A517-60A2-4FD3-AEB3-75716741C1B8_zps
93202CB9-6063-43DC-9A59-8371AC939911_zps
6463BDF2-E705-43B4-B126-B86FC4AC2173_zps
29CDBC87-7FC0-4AEC-BBBE-3688A0DAC626_zps
ECCD25BD-73E0-4654-9003-EF33A032C286_zps
9104C565-AB18-4AE4-82B4-5D39F7561600_zps
0D9A5E89-826C-47ED-8558-2517145296F0_zps
BBACCE18-D120-426F-8594-599D9BFCB945_zps
Cleaning up/after
5EA6F4A1-70D5-4187-975A-81838ACF7546_zps
3542EB26-D3E5-484B-AE46-67E81A4C803E_zps
0725D444-C10B-49EA-B5FF-E66606712069_zps
Having a very hard time with the spigot bush so I may go buy a removal tool tomorrow or try the grease method (which failed once today)
Looks good so far man. Keep up the hard work! I've yet to do a clutch replacement in mine!
Thanks Dan! I'm not at the stage of getting it back on yet but right now I have no problem doing it on the ground with jack stands and ramps. A hoist would be ideal but not impossible to do as I am.
Borrowed a blokes spigot bush puller and got the stupid thing out today. Tried to get a new one in and messed it up pretty badly so I'll have to try another method of getting it back in tomorrow with a spare I have here.
26E18841-FD62-43CA-A73A-009A2B1481EC_zps
Was going to do a DIY but I didn't take that many pictures because I was too grumpy. I would not do this without a hoist again, If the box was to come off again I would rent a hoist or do it at a mates shop. It's quite hard for me to get the car around until December so I had to go with doing it at home. Got everything back on today and a friend gave me a Wideband to go in the car also which I'll get a bung welded in for when it goes to JEM next month.
A run-down of everything that happened
I broke a spigot bush getting it in like an impatient idiot - So I grabbed my spare, greased it up, chopped up a spare alignment tool and pressed it in. Getting the gearbox itself back on took roughly 45 minutes of struggling with a trolley jack and my brothers help. A note on the torque of the flywheel bolts is by using a flat bit of steel with two holes 4cm apart on the pressure plate bolt and the bell housing bolt and torquing it up using that to hold it. The pressure plate bolts were done by holding it still with our hands.
Torque specs are here for those interested.
Balancer Bolt - 142-152
Flywheel Bolt - 124-152nm
Clutch Bolt - 34-44nm
I did the flywheel to 145nm and the Pressure plate to 38ftlb (yes I know different measurements).
517EE72C-2411-4571-9FE3-C13156622633_zps
916F129B-22E5-442A-B75A-07E738856ED8_zps
B9291788-1313-4E10-B264-CA9DCD8F7BAF_zps
D83C6CA9-C976-4A5F-942A-658E51794F00_zps
02025CD1-0ADC-4E9E-90BC-609F21E4009E_zps
If anyone else wants to do this at home send me a PM and I can help out by answering any questions.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
