Wts My 32 Gtr 560Hp On 22Psi
My 32 gtr is up for sale made 560hp on 22psi on pump 98. Was rebuilt less than 10k ago by cs mmotors. Running a gt4094r eboost street. Full adjustable Coilovers. Os giken twin plate cluth. Chasing 23k ono. Located in Townsville. I have probably missed a few things so if your interested send me a pm or msg on 0423041840 cheers
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
I hope this is a bit better.
I bought the car early in 2013 with 98000ks. As it stands now it's at 107000ks. It was rebuilt 3 weeks after I got it by cs motors here in Townsville.
The motor.
The turbo is gt4094r.
je pistons 0.020 over size.
scat rods. 2000 series rod bolts.
Std crank with collar and oil gallery mods.
Tomie oil pump with external adjustable regulator.
ARP head studs.
Modified oil and baffled oil sump.
External and drains and restrictions fitted to the head.
Supertech duel valve springs.
adjustable hks cam gears.
Camtech camshafts 272s.
Microtech LTC15C ECU.
Microtech x6 ignition.
Microtech LTC dash display with gps.
Id1000 injectors.
Sard fuel rails.
Magnafuel fuel pressure regulator.
Twin 044 fuel pumps and 2.5L surge tank.
6 boost manifold.
Other points on the car.
Gearbox is Reconditioned from previous owner.
Os giken twin plate clutch.
Brand new Pwr radiator.
Eboost street boost controler.
50mm blow off vale can't remember the name of it.
Brand new battery and alternator.
The interior.
It has an alpine cd player that I never use.
It has aftermarket speakers.
No bubbles or cracks in the dash.
Seats are in good condition no rips or tares.
The steering wheel and the drivers side apiller are a bit ratty.
The outside.
Still have the standard rims as that's my style stock sleeper.
adent/scratch on the bonnet.
Some scuff marks on the front bar also.
The paint is on good condition otherwise.
I have run the car once at palmyra drags in Mackay it run an 11.6 @ 126 mph.
I'm not sure how to add more photos other wise I would. Il add more when I remember it cheers joey for the help.
  • Like 1
Great looking GTR, love the single setup! And in gun grey. Almost exactly the same as my old one only far neater.
Good vid on CS Motors FB page too.
What is its drivability on the street like with the GT40, when does it come on boost and how does it pull?
And no E85 tune?
Cheers Ben. It is laggy but I haven't really been in any other gtr to compare it too. I don't find it that hard to drive As I only drive it to and from work. I think full boost is about 4500rpm but it's only limited to 7000rpm at the moment with plenty left in it. In 2wd pretty much useless with stock rubber. Pulls hard in 4wd tho. There is no e85 on pump here that's the only reason why I haven't done it...
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
