HI all! I have a skyline 350GT which has the check engine light on.
I am looking for someone to check for fault codes in the bayside area of Brisbane, QLD if anyone knows someone not at Nissan?
I would take a guess here and say that the stealers will charge a small fortune to plug a cable in to read some codes! lol...
https://www.sau.com.au/forums/topic/451405-fault-codes-for-350gt-brisbane/
Thanks yeah I did the accelerator pedal and it worked but management light came back on.
I have just had the faults checked on the reader and came up with 4 culprits (apparently)
1. P0031 A/F SENSOR 1 HTR (B1)
2. P0051 A/F SENSOR 1 HTR (B2)
3. P0037 HO2 S2 HTR (B1)
4. P0057 HO2 S2 HTR (B2)
Is anyone familiar with these codes or had the same ones come up and found their problem?
The auto sparky says for checking each one of these it needs further work on a styroscope or something to that effect to
check properly the faults.. not sure how many hours at $88 p/hour it will take though... :angry: He did mention it could be a pre heat sensor source of some kind. :closedeyes:
I'm hopeful some fellow GT owners may have had these codes come up and successfully rectified the problem?
I have seen that fault many times, but usually one side not both banks.
Sounds like you need to get it on a consult 3 unit. You will have more luck getting responses in the V series section...
Where are you located?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
