Hey this might be silly idea but Im curious, what if you did a comp test , then did the adjustments would the right adjustment raise its compression the highest?
Edited by AngryRB
Hey this might be silly idea, but what if you did a comp test , then did the adjustments would the right adjustment raise its compression the highest?
Its not as simple as that.
Overlap will lose compression when testing like that, but raise the dynamic compression ratio higher in revs and make more power. Cam shafts and timing are crazy technical, mixed with black magic and heaps of guessing and testing to get it optimal.
Also depends what characteristics you are chasing.
A comp test tests part of the dynamic comp ratio but only tells you half the story, simple advancing the intake cam alone will give you a higher psi reading simply becuse it closes the intake valves sooner increasing the compression stroke lenght increasing the volume that gets compressed into the same area and due to the cranking speed used to do the test changes the VE
The best way to test and tune cam timing changes is on the dyno where you can see the slightest changes in a controlled repeatable evironment
  • 6 months later...
Okay so it goes back on the dyno to play with cam timing on Tuesday.
I think I will just start by doing what GTRPSI said as that should give me a good basis to work from.
Any other ideas/feedback appreciated [emoji4]
  • Like 1
Well if bet my left nut it's not electrical. Did absolutely everything myself and tuner could think of but still no avail. Thinking it could be a leaky injector seal or something similar.
Out of rego at the moment anyway so I haven't touched it yet.
Missfire started at 5500rpm and continued from there. Still make 340kw on 17psi with a safe tune to account for missfire only revving to 5500.
  • Like 2
Jez did question it (running standard cams/springs/etc) but we both felt it was electrical in nature and tried to pursue that. Ran out of time in the end but will go back and try and suss it out.
What other ways does valve float manifest itself?
Try running it up at lower boost and another run with more boost early on. If it makes it to say 7000 rpm without the "miss" and then when you give it more boost it happens at say 4800 rpm, good chance it's that.
I've had the same issue on my own car and it turned out to be float. Sounded like a missfire.
With 7psi gate spring it make 295kw on 14psi revving to 7krpm. I then put a 14psi spring in and went back for retune and minimum boost we could run was 17psi and it started missfiring, another thing, it seemed to get worse with heat soak, the more runs back to back the earlier it would start doing it.
Tried 2 known good sets of splitfires, and brand new BCPR7ES starting at .8 and working down to .55
Definitely not an issue with ignition. Started at 14.3V and dropped to 13.8V when miss started.
  • 2 months later...
how will you determine 4degrees on the intake cam?
Do you think the stock cams will do much being adjusted, im thinking the RB30 would love more beefy cams as you have higher comp and a bigger pump..
Edited by AngryRB
By moving it the same amount as the exhaust cam, I have marked the standard intake cam gear so have a reference to work with.
Yes aftermarket cams would make considerable difference I would imagine. But my standard baby neo cams seem to be doing quite well at the moment. Trent from chequered tuning has made over 400kw on standard neo cams so not looking like they will be a restriction.
Plus $700 buys a lot of tyres so the dollar/fun ratio isn't high enough for me to justify spending that much on some wobble sticks. [emoji4]
  • Like 1
  • 6 months later...
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
