Can You Hydrolock Break An Rb With Half A Can Of Carby Cleaner Down The Intake?
Ok today I changed the engine oil with 10w 50 penrite synthetic and its much much better in terms of smoothness and vibrations. Not back to its pre touched self, but I'm hoping the rest of the vibrations will even out, although I am doubtful. Its possible that when I sprayed the crap out of the blow off valve with carb cleaner a lot of it got sucked into the turbo and somehow made it into the engine oil diluting it and making it more watery. Same with running past the piston rings.
I have to say I have been feeling pretty gut wrenched about not doing the job right and in a hurry, but there was so much gunk and i just kept spraying and spraying.
Whats funny is the car now has a much more pronounced typical RB25 or 26 sound, with a lot more backfires under off low throttle conditions and rawness to it coming out the exhaust, whereas before it was more like a patrol engine. Smooth and wispy. Probably 15 years of carbon build up gave the metal parts a nice cushion and now there is more direct metal to metal contact. It almost sounds like a WRX relatively speaking.
Even though the idle smoothened out, when I slowly rise the rpm in neutral and hold it a certain level, say 2000 it still vibrates a lot more than I am used to, then smoothens out a bit between 2000 and 3000rpm, then gets a shaky again at 3300, then smoothens out at the higher rpms. Hmm.
Whats funny is the rich smell is still there but its getting less and less. It leads me to believe there was some pool of carby cleaner still left over somewhere, maybe in the intake, blow of valve or within the turbo system. I say that because I also sprayed the crap out of the blow off valve.
To go back to your question of 2 posts ago......if you have a cylinder full of liquid and you crank it over until it compression locks, then you will not damage the valves or the lifters. You cannot. Think about it. What you can do is bend conrods, damage crank and rod bearings (and probably gudgeons) and lift the head if the head bolts/studs are not up to it and/ore damage the head gasket. In extreme cases you can split a bore.
To answer your original question and what has been repeated in your last post.....who the hell knows if the stuff would still be sitting in the cylinder after 15 minutes? If there was more than 60cc of liquid in there then you will have definitely locked it. If there was enough force applied to bend a rod, then you are currently running with one or more bent rods, which will not be pleasant.
At this point you may as well spray a can of Subie's upper cylinder cleaner into it (following the instructions of course and see if you can clean it out more thoroughly and see what progresses from there.
You mean because the valves sit on the inside of the combustion chamber and when they close they rest flush against the metal upwards meaning the cannot be pushed up any further? Yea that makes sense, but it could certainly score them or scratch them making a less than perfect seating?
Im not so sure if I locked it at any stage... The engine didn't try to turn over and lock up at any stage. Just crank without starting and took a few good minutes to get going.
I guess I can always easily check if I bent a rod buy simply checking the heights of the corresponding pistons through the spark plug holes and seeing if they match up in height.
Ive never heard of subies cylinder cleaner but I'll look into it. Is that like seafoam? No chance of doing any damage by following instructions I take it? I have heard of seafoam causing damage even when instructions are followed
Edited by Touring
gap your plugs down to 0.8mm
1,1mm is about 43 thousandths of an inch
0.8mm is about 31 thou - still a massive gap
And don't forget the gap just grows as the km go by.
  • Like 1
Subie being Subaru. Their upper engine celeaner being the original and the best.
Can I ask what brand of cleaner did you use.
I have tested probably every brand of carby/brake cleaner over the years and bmw brake cleaner was the only product that left no residue. Recently I ran out and tried the bendix brake cleaner and it was better than most. The problem with all the other brands is they must have water or some other substance that does not evaporate. Circuit board cleaner is also a great product to use but you have to buy a quality brand and it's expensive.
Your cardinal sin was,,,as has been pointed out is never spray anything into an engine while it's not running. Actually never spray anything into an older engine.Clean your bits off the car mate. 20 years of carbon and slight sludge build up is a good thing for hydraulic lifters and the like.
Hope it all comes good.
Neil.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
    • @PranK, why do we have this restriction? Because photos are the first thing that gets asked of new people on the forums. Do the spam bots post photos if allowed?
    • How do you rate the clutch @joshuaho96? Sometimes I wonder whether it's genuinely very driveable or whether I just feel that way because it cost a good chunk of money. Most recently when seeing the guy at the tyre shop struggle to move the car...
