Can You Hydrolock Break An Rb With Half A Can Of Carby Cleaner Down The Intake?
Ok today I changed the engine oil with 10w 50 penrite synthetic and its much much better in terms of smoothness and vibrations. Not back to its pre touched self, but I'm hoping the rest of the vibrations will even out, although I am doubtful. Its possible that when I sprayed the crap out of the blow off valve with carb cleaner a lot of it got sucked into the turbo and somehow made it into the engine oil diluting it and making it more watery. Same with running past the piston rings.
I have to say I have been feeling pretty gut wrenched about not doing the job right and in a hurry, but there was so much gunk and i just kept spraying and spraying.
Whats funny is the car now has a much more pronounced typical RB25 or 26 sound, with a lot more backfires under off low throttle conditions and rawness to it coming out the exhaust, whereas before it was more like a patrol engine. Smooth and wispy. Probably 15 years of carbon build up gave the metal parts a nice cushion and now there is more direct metal to metal contact. It almost sounds like a WRX relatively speaking.
Even though the idle smoothened out, when I slowly rise the rpm in neutral and hold it a certain level, say 2000 it still vibrates a lot more than I am used to, then smoothens out a bit between 2000 and 3000rpm, then gets a shaky again at 3300, then smoothens out at the higher rpms. Hmm.
Whats funny is the rich smell is still there but its getting less and less. It leads me to believe there was some pool of carby cleaner still left over somewhere, maybe in the intake, blow of valve or within the turbo system. I say that because I also sprayed the crap out of the blow off valve.
  On 06/12/2014 at 3:44 AM, GTSBoy said:
To go back to your question of 2 posts ago......if you have a cylinder full of liquid and you crank it over until it compression locks, then you will not damage the valves or the lifters. You cannot. Think about it. What you can do is bend conrods, damage crank and rod bearings (and probably gudgeons) and lift the head if the head bolts/studs are not up to it and/ore damage the head gasket. In extreme cases you can split a bore.
To answer your original question and what has been repeated in your last post.....who the hell knows if the stuff would still be sitting in the cylinder after 15 minutes? If there was more than 60cc of liquid in there then you will have definitely locked it. If there was enough force applied to bend a rod, then you are currently running with one or more bent rods, which will not be pleasant.
At this point you may as well spray a can of Subie's upper cylinder cleaner into it (following the instructions of course and see if you can clean it out more thoroughly and see what progresses from there.
You mean because the valves sit on the inside of the combustion chamber and when they close they rest flush against the metal upwards meaning the cannot be pushed up any further? Yea that makes sense, but it could certainly score them or scratch them making a less than perfect seating?
Im not so sure if I locked it at any stage... The engine didn't try to turn over and lock up at any stage. Just crank without starting and took a few good minutes to get going.
I guess I can always easily check if I bent a rod buy simply checking the heights of the corresponding pistons through the spark plug holes and seeing if they match up in height.
Ive never heard of subies cylinder cleaner but I'll look into it. Is that like seafoam? No chance of doing any damage by following instructions I take it? I have heard of seafoam causing damage even when instructions are followed
Edited by Touring
gap your plugs down to 0.8mm
1,1mm is about 43 thousandths of an inch
0.8mm is about 31 thou - still a massive gap
And don't forget the gap just grows as the km go by.
  • Like 1
Subie being Subaru. Their upper engine celeaner being the original and the best.
Can I ask what brand of cleaner did you use.
I have tested probably every brand of carby/brake cleaner over the years and bmw brake cleaner was the only product that left no residue. Recently I ran out and tried the bendix brake cleaner and it was better than most. The problem with all the other brands is they must have water or some other substance that does not evaporate. Circuit board cleaner is also a great product to use but you have to buy a quality brand and it's expensive.
Your cardinal sin was,,,as has been pointed out is never spray anything into an engine while it's not running. Actually never spray anything into an older engine.Clean your bits off the car mate. 20 years of carbon and slight sludge build up is a good thing for hydraulic lifters and the like.
Hope it all comes good.
Neil.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
