The following bits are from a recovered R32 RB20DET that was burnt out. All prices are negotiable
I was told the engine still ran, however i didnt test it, just took the bits i needed and this is what is left
RB20DET Head - no cams, needs a wash $20
RB20 Flywheel $15
RB20 Manual Sandwich Plate $10
RB20 Fuel Rail with aftermarket regulator adaptor - has got a bit hot at the rear end but still straight $15
RB20 Power Steering Pump $25
Aftermarket Fuel Pressure Reg $20
4x Pink top feed injectors $15
Located Croydon, Vic. Happy to do postage on the smaler stuff, but the head will need to be picked up.
https://www.sau.com.au/forums/topic/451451-fs-rb20-flywheel-head-ps-pump-etc/
  • 1 month later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
