Itd be too much stuffing around trying to get AWD from a VQ35, you would just stick to the VQ25. Which is oh so original and exciting.
You know they made an awd vq35 stagea, yeah?
Love your work, seen many similar conversion start but never finish... but you seem to be smashing through all obstacles with great precision!
Down the track I hope you drop in the 4.5L crank and tickle the bores :)
Absolutely loved the series mate. I've been thinking for ages that a turbo V8 would be perfect in the Stagea. Good on ya for sticking with the manual box. It's gotta be a lot of fun. I must say the amount of detail in the series really drives home how much effort is required to do an engine swap like this. Bloody heaps! Damn awesome work. The workmanship looks second to none.
Why a VQ35 is the real question.
The VQ35 is an underrated engine. People didnt take to it for tuning the same way they did with an RB engine despite the fact that it actually lends itself to forced induction well. People using the HKS twin turbo kits are pushing around 400-450 rwhp on only 7psi of boost . The V series skyline was also used to test engine/drivetrain configurations during R&D for the R35 GTR. Ben did also say he wanted a nissan derived engine too, but that V8 was a good choice too
  • 7 months later...
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
