I thought it was stupid Windows 8 issue not sau, as I have the same problem posting on extremelysexysex.com.....I mean, another website...
but yeah yeah the bbcode thing seems to work fine for quote/paste/attach..
  • Like 1
oh I see.
was deluxe, same issue with whatever I just changed to. But now I can't select "change theme" again to work out what I changed to
  • Like 1
oh I see.
And here I was thinking you were being a smarty pants.
I think it's called 'skin' on some and 'theme' on others. Granted I'm on deluxe and it says 'theme' :(
Ok, I'm going to raise a ticket with support and see whats what.
hmmm not sure that the solution to 1 website not working is to change my whole computer setup.... :blink:
I'm not sure IPB actively support the latest IE though? There are many people complaining over the internet about IPB boards and compatibility with IE11... SAU is certainly not an isolated instance of these problems.
It's the only one that I have issues with , and I'm on heaps , I'm running up to date windows 7 and will be until the wheels fall of , can't stand 8 its a crock.
Yeah I am too - but are the others non-current versions of IPB? (last 12 months).
Or are they vbulletin, phpBB, SMF which are the other top choices?
SAU is the only forum I use that is actually IPB, oddly enough.
  • 3 weeks later...
Hi guys, I installed a patch today that was reported to fix this issue. Can you please test?
well done !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
  • Like 1
Still no worky for me, thanks for trying though!
when I hit "Quote" with BBCode mode on, it does not quote anything. If I hit quote with BBCode mode off it quotes the post in the quick reply box
Works for me combo of BBC code on and off -----tuning sorta-- :yes:
IE is rubbish, just change browser, not exactly changing entire computer setup, pretty basic really. I have had many problems on many websites and browser games for a long time using ie, other browser work fine. My preferred is Firefox/Waterfox.
More and more Microsoft are acting like apple and not being compatible with things properly :(
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The  I have researched this so much, I may soon become nut and washer expert. so side of washer which is cut or cone shaped should face nut and inward looking convex should face pully? this aligns with what I found online   "Yes, a conical washer, also known as a Belleville washer or spring washer, has both a concave and a convex side. The concave side is the one with the smaller diameter, while the convex side has the larger diameter. When installing, the concave side is typically placed towards the surface being connected, and the convex side faces the fastener head or nut.  "   seen some people just replacing nut and stud with bolt, I assume that is no good as tension won’t be kept on tensioner right?   just to be 100% sure pressure washer faces the pully and then conical washer, it seems stranger as it is normally other way around/ pressure washer first facing bolt or nut:)
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
