I thought it was stupid Windows 8 issue not sau, as I have the same problem posting on extremelysexysex.com.....I mean, another website...
but yeah yeah the bbcode thing seems to work fine for quote/paste/attach..
  • Like 1
oh I see.
was deluxe, same issue with whatever I just changed to. But now I can't select "change theme" again to work out what I changed to
  • Like 1
oh I see.
And here I was thinking you were being a smarty pants.
I think it's called 'skin' on some and 'theme' on others. Granted I'm on deluxe and it says 'theme' :(
Ok, I'm going to raise a ticket with support and see whats what.
hmmm not sure that the solution to 1 website not working is to change my whole computer setup.... :blink:
I'm not sure IPB actively support the latest IE though? There are many people complaining over the internet about IPB boards and compatibility with IE11... SAU is certainly not an isolated instance of these problems.
It's the only one that I have issues with , and I'm on heaps , I'm running up to date windows 7 and will be until the wheels fall of , can't stand 8 its a crock.
Yeah I am too - but are the others non-current versions of IPB? (last 12 months).
Or are they vbulletin, phpBB, SMF which are the other top choices?
SAU is the only forum I use that is actually IPB, oddly enough.
  • 3 weeks later...
Hi guys, I installed a patch today that was reported to fix this issue. Can you please test?
well done !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
  • Like 1
Still no worky for me, thanks for trying though!
when I hit "Quote" with BBCode mode on, it does not quote anything. If I hit quote with BBCode mode off it quotes the post in the quick reply box
Works for me combo of BBC code on and off -----tuning sorta-- :yes:
IE is rubbish, just change browser, not exactly changing entire computer setup, pretty basic really. I have had many problems on many websites and browser games for a long time using ie, other browser work fine. My preferred is Firefox/Waterfox.
More and more Microsoft are acting like apple and not being compatible with things properly :(
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
