were the pads you tried OEM or aftermarket?
sometimes aftermarket pads do not sit the exact way OEM pads would and leave a bit of a gap and may be sitting a bit loose in the caliper. Go supercheap and buy some brake squeal stop or whatever its called. Its a red paste you spread on the outside of the pads and once it drys, it becomes rubbery and helps bridge small gaps you may have between the pad and caliper.
Edited by Abdul11
na i dont iv'e been trying to buy some can't seem to find anyone who sell them iv'e always put FB status's on drift sales and other pages, i went to my local nissan dealer my they said you have to go to a bigger dealership like doncaster Nissan or some shit also i took my caliper off today and i saw my rubber on my brake piston is cracked and exposes the piston a little do you reckon that could be a reason, i might try a full caliper rebuild
haha ill do a full rebuild next week and ill see how it goes, does anyone know where do get some brake shims honestly iv'e been looking over two month's cant seem anyone who have any
A wrecker.
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
