T67 ebay version is a 25G on a L2 turbine. 25G compressor is good enough for 430rwkws while the L2 turbine is good for 370rwkws. In combination the maximum I'm seeing was about 370rwkws on 23psi, factory cams. they don't last long at that boost level either. Commonly seen Greddy T67 consists of 25G with TD06H turbine is fine for both longevity and power making, but it does cost responds.
In addition, we build some alternatives based on the 10cm L2 turbines that makes the same power as the L2 based 25Gs, that are more responsive, last longer at similar cost. Check out SL20.5 and SLSS2 on Rb25det dyno section.
well ive run into a bit of drama with a noise, not sure if the cams have caused it or bottom end, but apparently bottom end knocks dont go away once warm like this does. plus my vct gear is on its last legs.
but yes still going strong when i do drive it.
Edited by methz
I had a Kando T67 with a TD06L2 exhaust wheel in 10cm. It made 368rwkws on 24psi. First one lasted 4 month and the replacement lasted 3 month. They no longer reply to my emails now. Photo of the last one:
Edited by petero'nell
Greddy differentiate their T67-25G and TD06H-25G for that reason. A TD06H-25G is actually bigger than a T67 in Greddy speak. They share the same compressor side but on the hot side the T67 uses the smaller L2 turbine.
If you have seen a Greddy turbo with a 25G compressor and the TD06H turbine then it is a TD06H-25G...not a T67-25G or what is referred to commonly as the T67.
Cant speak to the reliability of Kando turbos but it does seem possible that the later ones are a little more grenade like than the earlier ones and definitely Trust turbos. Trust turbos just keep on keeping on. Though these days with E85 and boost over 25psi I do wonder whether the would be as happy in the 25-30psi range as they were in the 20-25psi range
  • 3 weeks later...
  • 8 months later...
  • 1 year later...
Is there quite a few Kando T67s that have failed at around 23psi on a 25?
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
