18 hours ago, bcozican said:
I just remembered !
https://kiwicnc.com/en-au/products/nissan-r32-33-34-gtr-motorsport-uprights
little bit out on pricing though - rounding error
I sound like a performance workshop now 😆🤐
What's another $10k, you don't need to eat right?
Interestingly the guy from Brypar said don't worry about the rear uprights, apparently there's not much to gain there.
What is the advantage in the billet setups, vs the factory one?
I can't see how those will fix your issue of tearing subframe as they don't appear to change arm positions etc, which means you'd be changing the hubs but subframe is weak point right now.
Think that part of the discussion developed from my hub bearing issues not in relation to subframe situation
Double A arm and associated upright wld solve alot of issues but... yeahhhhh
  • Thanks 1
Currently working on increasing the effectiveness of the cooling system while simultaneously improving aero.
Previously with oem everything up the front it was hard to package everything and get it working efficiently but we did a pretty good job. Discussions where had and the move has been made to stack the intercooler/ oil cooler and rad together, completely seal it and vent it out the bonnet.
We stopped short of a full tubeframe front .. well just because... but everything got moved forward and tilted forward
The intercooler has been flipped back to traditional position, this has increased the cooler piping length but quite a bit but considering how this thing it tuned and manages boost,  response will not be affected
Previously had a 25 row oil cooler and carbon shroud with 4" ducting going from the front bumper directed into the wheel well. This actually cooled very well but considering I was doing all this, I want to to the wick up  a bit more and aero wise it wasnt super effective having hot air going on the tyre, brakes and into a high pressure wheel well there is now a 50 row Setrab sitting sealed inbetween the intercooler and radiator.
The venting will obviously go out the bonnet reducing under bonnet high pressure area and taking away unwanted air going under the car.
The tyre warmer turbo/ front tub cutout has now been sealed off which we previous didnt get to
Keep on ticking away this bit is nearly finished will now pull it apart and make it a little bit more pretty also though the raw chromoly and ally go ok i think too
Edited by bcozican
  • Like 8
2 hours ago, Duncan said:
Very complex piece of work there, will be good to see how it goes.
Is the front bar just going to slide in on pegs and be retained somehow?
it better go good 😅🤞
The splitter is supported at the back on the front cross member and has a frame at the front that just slides into the slots in black either side of the intercooler - these are connected to the chassis rails
There is an air dam built onto the splitter
the bumper then just sits up against the air dam, seals against the intercooler and its pulled tight and dzus clipped on each side
  • Like 1
  • Thanks 1
I really like how you're still using the factory runners & a NEO head, in some way I regret not sticking with the OEM intake manifold.
Lost like 200~300rpm of downlow response moving to the shiny Plazmaman intake manifold.
😁 it does the job nicely!
Theoretically you get higher top end
We can swap !? Think we could manage the 300 rpm although dont think I need more top end 😅
Edited by bcozican
haha only if you pay for the fab work :D
Will need a new cold side pipe, and most likely need to chop up my catch can to allow the e-throttle to clear with the pipe work
  • Haha 1
I’m going to give the Rajab Racing manifold a go when I do my build next year.  They told me they are developing an improved exhaust manifold similar to the stock one which I’m excited about
  • Like 2
Did you full weld those tubs in? I was advised to just stitch mine in to allow a small amount of flex and make it easier to remove/repair.
Feels weird to not fully weld a piece of body panel though 0_0
100% fully weld
im not feb guy / car builder etc but I dont see why you wouldnt want as much rigidity as possible + when are you ever going to remove or repair ?
Edited by bcozican
The advice came from a good panel beater mate of mine.
Too rigid causes cracking in seam sealer (if used) and paint over top. Makes any repairs harder to do. There's always flex and having them fully welded can move the forces elsewhere.
When removing the factory tubs, they were just spot welded in also. Re the towers, I'll only be stitching those at most, it wont be full seams.
I think I'm comfortable going with his advice, was just asking what you did/how it's held up.
  • Like 1
1 hour ago, bcozican said:
ive not had any cracking or anything of seam sealer/ welds or anything
my cage goes right through to the front strut towers so maybe my car is rigid already so doesnt effect as much
Same here, no cracking but my cage also goes end to end.
  • Like 1
  • 3 weeks later...
Because build thread...
Pulled the fab apart, I got on the paint brush and tidied it all up. My bit is good from far but far from good but hey... racecar
Now to run some new oil and ps lines bang some bigger injectors in and send it
Edited by bcozican
  • Like 5
  • 5 weeks later...
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
