First I'm going to start with restoring your headlights with toothpaste.
I'm guessing most people know about this but if you don't it's going to cost you 50c rather than a $30 headlight restoration kit from an auto shop.
If you have an old imported vehicle from japan it's most likely going to have yellow headlights. This is how you can make them brand new for next to no money.
1. Clean headlights with water and a clean rag.
2. Apply whole headlights with toothpaste
3. With rag scrub the tooth paste into the headlight trying to remove as much of the oxidation as possible
4. Clean tooth paste off with water and wipe dry
You can do this again to get them more clear if they are still a little yellow but it should work first time and look brand new!
tip - Clean one headlight first to see the difference and you'll be amazed.
(More post's to come later)
Ask to see room at hotel, steal toothbrush kit from bathroom while viewing room, then tell them u don't like 'the vibe' of the room and don't check in. Raid salvo's bin and nab old t shirt. Result, free tools for headlight mod.
But agreed, thread title could be 'broke-ass mods' or similar. Anyway, 2 faves are, plug up bypass hole in base of bov for more responsive throttle, and 3in pipe into rubber intake mods. Cheap n good.
  • Like 1
Nothings going yo make your na cat actually go better for free.
So, i actually reccomend a semi thought out hole in airbox will make some more induction noise and is free. Will suck hot air but won't matter. Will sound slightly better.
Not sure if na skylines have a resonance chamber type thing on their inlet, probably do. If so get rid of it. Car will sound better.
I cut a big slot on my R31's airbox, makes a barely audible purring noise when you close the throttle. Also makes the air filter dirtier quicker. Apart from that, no difference. In fact, complete airbox + snorkel apparently gives you slightly better fuel economy. LOL
Check tyre pressures.
I've been guilty of driving with lower than optimum pressures especially if the car sits for months at a time.
Yes! Me too. I was going to suggest buying a hand-held pressure gauge but that would make it not 'free'. :)
Take a big shit before a drive. Weight reduction ftw.
Also, diet. Save money on food AND go faster.
I've done this personally :)
Lost 20 kilos so I'm no longer a fat shit. Better power/weight ratio, fuel economy & health lol :P
But also taking out all the crap/junk that's in your car all adds up too for whatever little weight benefit it provides. At least you'll have a clean car for sexing the ladies ;)
This thread is going to provide some good laughs by the looks of it. My suggestion was what Hadouken beat me to, take off your CAT, bash it out, bolt back on. You get killa pop on the downshift sometimes and who doesnt want that?
  • Like 1
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
