this has been happening very recently, yesterday i was driving then while going in for a turn my r33 stalled on me
happened again today was turning then stalled on me
i noticed it happens when i press the acceleration firmly then let go and go in for a turn it stalls
could the OD function be the cause for this?
ill also note that i usually have to press down the gas pedal when starting the car otherwise it just wont even attempt to turn over
I'm pretty sure I know what you are talking about. When you come to a stop after being at speed say above 40kph, the engine just dies very peacefully at the moment the car stops. You are close when you suspect it has to do with the transmission.
I'm at almost 100% certain it is due to a malfunction in the automatic transmission where the "clutch" does not disengage gear fast enough to allow the engine to keep turning with the wheels stopped, and thus stalls it.
The malfunction will be due to wear in the auto box or old fluid or a low fluid level or most likely all of these. Saggy transmission mounts can also cause the transmission to "stick" for longer than it should so get that looked at as well.
Here is my recommendation to you and I'm almost certain it will fix your problem.
Change your automatic transmission fluid with Nulon synthetic. Do a complete flush, as in take out the line that feeds out of the transmission cooler back into the transmission and let the car run pouring out waste fluid while someone tops up fluid until new fluid starts coming out. Then drop the pan clean the pan and magnet and filter. You can buy a gasket set from repco for $50.
Top up again with the car In park and keep checking fluid level to be on H mark with car warm.
Clean Your AAC valve.
Advance your timing a little bit.
Edited by sonicz
Maybe.
But afm reverberations do make the car stall when snapping the throttle shut. Running a bov and checking if that fixes it is easier than a trans flush (although you should do a trans flush anyway, I don't think it will fix the problem though)
The "advance your timing a little bit" is poor advice. What's a little bit?
I wouldn't be recommending randomly advancing timing on any car, let alone a turbo.
Yes that could be it as well, though if that were the case would it not happen and bog down at any speed? Say if you were to pop the car in neutral while driving?
I went into the specifics I did because I've dealt with the exact same problem and got all sorts of talk about AFRs and injectors, intakes and electronic aspects which I found strange as the car did not exhibit any of the problems expect when at very low speeds and then stopping which led me to believe it was drive train problem the ecu was not expecting. I could feel the car holding gear too long when slowing down and the gear not disengaging properly to allow the torque converter to work and staling the engine. I changed the gearbox mount and flushed the transmission (it was low when checked as well) and it solved the problem completely.
Cleaning the AAC vavle and advancing timing helped a lot at making the car hold good idle rpm faster as well before I did the above and almost eliminated the problem though it was not the root cause.
As for advancing the timing I agree its dangerous, but based on my experience (not that it means much) most rb25 skylines have a large safety margin when it comes to advancing the timing via the CAS. I.e most are running colder plugs than they should, running richer than they should, and I have never noticed noticed a stockish one pinging after a small advance. By small i mean just turn the cas maybe a few mm. When he said he has no BOV I assumed he means he just has a stock skyline with the stock BOV, not no BOV. With slightly advanced timing the car just responds to changes in RPM much faster and was better at catching the stall in my case.
After I found out what the problem was and went back to stock 15 degrees timing but just hated it and kept it a little advanced. I know people that keep the cas at full advance and nothing sounds like its pinging. Why is the stock timing so low on RB25s anyway.
OP we need more info, does it happen when you come to a complete standing still, and can you prevent the stall but quick;y popping the car in neutral when you feel it about to stall?
Edited by sonicz
  • Like 1
Agreed, if issue is happening with timing set where it should be, don't 'solve' it by advancing timing. Could well be auto trans pressue issue though, if not engaging overun clutch properly to keep engine revs up when going to closed throttle? I think, anyway, its what mine is doing and the issue i'm looking into.
Nah bro, more timing is hektik. Thats why its called an advance, and running less is just retarded :whistling:
Edited by sonicz
the auto trans fluid was in nick condition & plenty in there, didn't need replacing but i did a quick flush anyway as i already had bought the fluid
its never stalled while at a stand still both the times it happened was while i was moving in for a turn
i truly dont think its due to not having a bov iv been running without one for a fair bit now and has never ever done this till just recently
as a matter of fact started happening couple days after i put in a catback system
ill just have to take it in to a mech to get it looked at
a little update..
few days after i posted this thread my turbo comepltely f**kd up i took a look and the shaft had like 3cm play literally
so im guessing the turbo was the reason why my car started stalling
just finished removing & installing the new turbo few hours ago (first time & did it alone) and everything seems fine
the actuator on the turbo is set at 11psi though when i took it for a run according to my gauge it got up to 16?
i know the actuator is rubbing against the side of my car could this play a role in this?
Edited by DN14
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
