Hey guys,
Been stalking the forum for years im normally a euro guy had several BMW's over the years and still got a BMW wagon currently getting engineered etc but i have also picked up myself a R34 GTT. Plans for the R34 are a street/track combo but abit more track based so road comfort and drivability arent too much of an issue should also note going for grip combo not sliding..... did drift im no good at it im gonna stick to grip work lol
Im currently on my P's in SA and have been given excemption to drive turbo to and from work etc so my missus is going to be driving it to the track or throwing it on a mates car trailer. But im currently collecting everything to do some performance upgrades and hopefully reach a comfy 300rwkw, i have so far collected TOG exhaust manifold, TD06 20G 8cm internally gated Kinugawa, 660cc injectors, PFC + Controller, FMIC(Fitted), Z32, Walbro 255, Split dump(Fitted), Down pipe(fitted), 3" 100 cell cat(fitted) so its pretty close to all being there ready to go just waiting till full licence to fit it all.
So currently im working on improving the grip of it. I have fitted adjustable Lower front and rear arms, front radius arms/castor arms, rear toe rods and there all rose jointed. Ive fitted some bendix SRT Pads and HEL braided brake lines and a brake master cylinder stopper and im running Kumoh KU36 semis. im going for whiteline 27mm front sway and whiteline 24mm swaybars there currently on order it already has some HKS coilovers in it and a good diff but oneday might go a KAZZ 1.5way. currently im looking into different bracing i can do to the shell so front and rear strut braces under body braces etc so anyone with some knowledge give it to me!
Also anything else you can reccomend to fit would be amazing! also looking into rough wheel alignment specs atm im at 7deg castor 2deg front camber 0.5deg rear camber
I seriously doubt he's got an exemption, he'd just be one of the few who risk having there cars impounded/crushed plus several years of loss of license, just to get a turbo car a few years earlier... I dunno, maybe its just me but it doesn't sound like its worth it.
Unless he registers it in his parents name (or older full licensed driver) and plays dumb once pulled over? I dunno probably won't stop the impound/fine/loss of license.
Nice car though, should have paid the extra $100 and got the 1000cc's as the 34 gtt is a top feed rail.
Basically you have to apply to Motor reg here in SA and tell them your situation and they will determine if you have legitimate reason to need to drive the car or if you dont. Mine is the fact that my other daily my wagon is defected and its the only other car i own so they gave me the exemption but i have had a couple of mates denied an exemption before
No for the exemption your not allowed to have performance mods and if you do you have to tell them. so i told them it has a turbo back exhaust upgrade and a FMIC setup and they have said that that is fine. there not fussed about any suspension modifications for the permit so none of that matters. thats why im currently collecting everything to get the 300kw but waiting till i get my full licence to install it all as i said in the first post..... Also i got the 660's because i paid $50 for them won them in an auction on ebay will receipt for the service on them and spray pattern and flow test sheet so for $50 i figure if they are 80% or above im going to get some ID1000's but im not too fussed if some ID's come up ill buy them but i have another 6 months till i get my full licence
Yeah if its not a motorsport build then theres the Projects, Overhauls and Builds section.
There are model specific forums for other less common models in the Vehicle Specific Discussion section.
thankyou sir! I will start a thread now and hopefully get some pics soon I work in a fabrication shed and ive been using my car to teach me abit more stainless and aluminium tig work so will try get some pics of that too
  • Like 1
  • 4 weeks later...
Hi Guys
new here, just joined SAU Vic recently, like others, have always liked Skylines, currently have a modified r33 gtst s2 , interested in the track side of things, looking at doing a lot more modifications, in the near future. at the moment trying to make the mods that I've done, work efficiently :wacko:
Welcome Adam :)
maybe start up a build thread and introduce yourself and your car, and in the thread explain your problems and I'm sure someone will be able to solve your efficiency dilemmas.
- Dan
  • 3 months later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
