Hey guys,
I have just recently purchased my 89 GTR.....
I've had it for a couple of weeks & now i'm having starting issues - when i start it, its sometimes a little rough but fine when i drive, but if i try and start it while its warm or leave it idling the cat light comes on & the car shuts itself off- mind you its only idling for 30 seconds tops, battery light comes on & also the oil pressure goes right down & light comes on also.
I have absolutely not a clue whats causing it..
Any ideas?!
:wacko:
https://www.sau.com.au/forums/topic/451700-cat-temp-light/
But would that cause the car to just not turn on?
i am a bit confused as to why the battery light & oil pressure lights are coming on too & would it normally completely shut the car off?
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443288
It sounds like the car has a few issues which is a given given the car is 25 years old now so it is going to be a case of one thing at a time, the cat light is there to indicate the cat is dead so change it and go from there, cat convertor a are a service item and need to be changed periodicly, even worse if it still has the compliance cat
The oil pressure problem is a common one with 32s unfortunately which requires a seperate oil pressure test and then new sender unit
As for battery I had an issue like this year and years ago and it turned out to be the fusible link connection at the battery had corroded, I cut it off and put an eyelet back on and no more issue
  • Like 1
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443312
Yeah, it does have a few issues......
I think i might take it to a specialist.....
Anyone know any good ones in/around Wollongong
it would make sense though if the altenator was going dead - that wld explain the battery light & also the Cat/engine light - but oil pressure... not so sure...
The gentleman who i bought it from said he has recently replaced the battery... so it could be a start point
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443355
Hey guys,
... the oil pressure goes right down & light comes on also.
Any ideas?!
:wacko:
Have you checked the oil level in the sump? Have you changed the oil recently? (if not, maybe you should).
My experience is that the oil pressure light is usually not caused by a fault in the sender; it genuinely means that there is no oil pressure.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443429
I can't remember now (it's been a while), but a flashing cat temp warning light means something is wrong with the ECU?
I haven't had a factory ECU since 2006 but iirc the cat light isn't connected to the ECU and it's the engine light flashing is an ECU fault but could be wrong
The oil pressure gauge in the RB26 in R32s playing up is realitively common, especially in the earlier ones, but is something that should be takin on the side of caution and tested properly before moving on
  • Like 1
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443444
I also had low oil pressure readings, changed the oil pressure sender with a new one and issue fixed.
Cat probe is a temperature sensor, when i first got my GTR the probe was not in, just coiled up under the car and the bunge plugged off.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443457
XKLABA,
You are talking about the gauge, and, yes, they are problematic in that the sender sometimes fails or gives erratic signals.
I'm talking about the "Oh $HIT" light. I can't recall ever having the light come on even if the gauge is reading 0. Only time is when I genuinely have low oil, and therefore low, ie 0, oil pressure.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443496
I can't remember, but last year when I put in a spare Nistune'd ECU in my car, a light was flashing (to indicate faulty ECU, sigh).
From Nistune:
Nistune Installation and Communications Diagnostics
Guide Page 18 of 28
6.2 Type 2 boards
Check section 4 if you can’t connect to your ECU.
Signs of limp mode on common ECUs:
1) R32 RB20DET, BNR32 RB26DETT
• ECU red LED and Exhaust Warning Light on dash will flash on / off
• Will not be able to connect to the ECU using consult
• Vehicle may start in limp mode but will not rev above 2000rpm without leaning out
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443505
I just checked the oil level - just to see....
Its on high, but it smells a bit like fuel (not sure if thats normal or not)
But the cat light/engine light doesnt flash - it stays on & the car wont start .... when it cut out on me whilst idling the other day it came on & the car turned off within a second... it was weird...
Im pretty sure ive got two issues going on atm...
Im going to do an oil pressure test & gut the cat at this stage... see whats going on...
Because mine is an earlier GTR im not sure if it has two sensors for the cat or just the one... a mate was saying if there is two i think you can disconnect it & bridge it somewhere ( i cant quite remember)
Ive got an Apexi Power FC here ready to go in if need be
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443678
Yeah i think at this stage im just going to gut the cat..... Ive got the boost pretty low so i doubt thats it.....
i honestly think ive got a few dramas atm.. which isnt unexpected, its an old car :)
But she is still my girl no less!
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7443695
If you have fuel diluting the engine oil, you have a problem. I would strongly recommend an oil change immediately, then investigate why the oil is being contaminated by petrol (possibly a blowby problem).
And gutting the cat can be highly expensive - if you get caught with a gutted cat. Replace it if you think it's contributing to the problem.
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7444501
So, i have an update....
I was driving it to the place i was getting it looked at.... the light came on while i was driving & i lost all power... I changed down gears & pumped the accelorator, until i finally regained power & it made a bang sound... then i regained power & it hasnt boosted so hard since i have had it. ANDDD the light hasnt come back on since :) :)
Im de-gutting my cat this weekend, so i will see how it goes again....
https://www.sau.com.au/forums/topic/451700-cat-temp-light/#findComment-7449096
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
