I have looked through the forums and have come up with a few posts, but all seem to be different to my situation
Put simply my car is Basically Stock, Pod ( in a insulated box ) and a 3Inch turbo back Stainless exhaust. 4inch hotdog in the middle and a very free flowing Cat
other then that completely stock, no boost controller, turbo timer, bov etc. so nice and stock
Once the car is at a operating temperature, It will give occasional little "pops" and after a good 5minutes of driving aggressively it will shoot flames with a nice bang.
now im not complaining. it sounds great and looks awesome,
it's not running rich, or Lean I am getting on average 380-500kms per tank and 10-12L per 100km. with a good 10L left in the tank when I fill up.
now, everyone else is blaming the cars, tuning or lack of a cat. I am assuming mine is simply because of the cat.
As everyone in other posts have recently had a Tune or car is running badly etc and mine is not, I figured I should simply ask
I am also not losing power etc. have had this exhaust for 7 months, from the moment it went on the car did it. nothing has changed since
if there is a post I missed explaining this further, my bad, guess ill look harder next time.
Edited by CaptainFresh
"have had this exhaust for 7 months, from the moment it went on the car did it"
"it's not running rich, or Lean"
"everyone in other posts have recently had a Tune or car is running badly etc and mine is not"
"I am also not losing power etc"
i might have missed the actual question?
Edited by GH05T
.... wow, I forgot to actually say my question. simply put,
would my car be doing this because of the exhaust or is there a more serious underlying problem, as the car is still running beautifully i'd like to double check
I was meaning no aftermarket bov. the car is "nice and stock" didn't think I had to specify everything that was stock. as I already said the 2 only mods on it.
other then that completely stock, no boost controller, turbo timer, bov etc. so nice and stock"" thought that was fairly clear.
i would say if you put a big exhaust on with a "very free flowing cat" and from that day it started it then i would highly suggest this is the cause, but if its only causing this then i doubt there is any other underlying issue.
if it were me maby its time to get it tuned a little
I wouldn't worry about it.
Perhaps it's running a touch rich, well it would be due to not being tuned. They all run too rich.
I asked about the bov as people consider (incorrectly) running no bov or a blocked bov is still stock.
  • Like 1
You don't say exactly what condition causes it to "pop". It might be that the TPS isn't shutting off correctly, causing the engine to over-fuel on gear changes (throttle closed situations).
The flames can often be caused by a small leak in the exhaust that allows fresh air to be drawn into the exhaust to mix with hot fuel-rich gasses, creating an explosive mixture.
Is the car Manual or Auto?
I only ask as mine was factory Auto but converted to Manual but still had the Auto ECU.
It would pop etc when off the throttle (especially with gutted cat).
Changing to a Manual ECU reduced it.
Edit* Great Flame Photo too. :thumbsup:
Ok thank you for the replys, the car is factory manual. So not concern with Ecu.
I will be getting a tune once I get a intercooler anyways...
No leaks in the exhaust, all brand new. no loose bolts etc.
It seems to do it very often.. since do writing this I've got my mate to follow behind. Once I've been driving for 20 or so, of normal driving. If I full throttle through 2nd, as soon as I change gears a nice big flame.. makes for great footage lol
Very noticeable at night, scared the crap out of me, thought I went past a speed camera
Not concerned with police, I live in a semi rural location. The police station closes at 4 in the arvo, so basically the police dont care
I am more concerned with the possibility of it doing damage somehow.
Thanks for the info/help.
  • Like 1
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
