Thanks Tom,
I take it from your post that you need to be a member of Costco to get fuel there?
I heard that the Caltex down the road has been forced to drop it's price to compete with Costco! I havent been out there to check it out though, busy with useless bloody xmas catch-ups.
Thanks for the tip mate ..
https://www.sau.com.au/forums/topic/451741-costco-fuel/#findComment-7443766
Confirmation on supplier would be good. Google search found Mobil and Shell??? But unsure.
Having had issues with Caltex in the past and at the time not realizing that 98 fuels aint 98 fuels, (much like oils) I would be very wary.
  • Like 1
https://www.sau.com.au/forums/topic/451741-costco-fuel/#findComment-7443798
I'm going to email costco to find out.
What do you mean about 98 and oils not being what they claim? I was thinking it would be more about how old the fuel is?
Apparently 98 doesn't mean 98 always. I read a paper somewhere where they tested all of the suppliers 98 fuel and some were as low as 96. If memory serves BP was the highest and most consistent. Hence I've only ever used them for 98
https://www.sau.com.au/forums/topic/451741-costco-fuel/#findComment-7443834
Are we talking 98 Octane or E98?
98 Ron Petroleum.
I paid 1.13 with a 4c discount for E10 the other day at a shell on the Hume highway... shits getting cheap!!
go Costco!
What vehicle do you put E10 in?
https://www.sau.com.au/forums/topic/451741-costco-fuel/#findComment-7443870
What people don't understand in Canberra is that there's not much competition so prices go up,plus factor in transport from the nearest pipeline or shore. basic economics. Fuel is probably sold I'm this state at 100%+ profit. That's why the servo next door reduced their price not that they run at a loss at all.
And if you look at the oil price per barrel from UAE they have dropped hence cheaper fuel. F*?n E85 hasn't dropped though!!
https://www.sau.com.au/forums/topic/451741-costco-fuel/#findComment-7445463
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
