33wishes Posted December 14, 2014 Share Posted December 14, 2014 So I've read some where on here, what does the little hole do on the inside of the end plate of my bov. I remember something about blocking it up. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/ Share on other sites More sharing options...
hypergear Posted December 14, 2014 Share Posted December 14, 2014 Its a re-circulation valve. I believe Its there getting rid of compressor surge. Proper BOV is recommended. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7443903 Share on other sites More sharing options...
33wishes Posted December 14, 2014 Author Share Posted December 14, 2014 Oh! Sounds like I need a new one, any recommendations on a tight budget. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7443914 Share on other sites More sharing options...
scotty nm35 Posted December 14, 2014 Share Posted December 14, 2014 Tight budget, just tap an M5 grub screw into it, at least that way you can remove it if you don't like the way it drives... Otherwise the Turbosmart Kompact plumback is perfect to replace it. 1 Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7443917 Share on other sites More sharing options...
KiwiRS4T Posted December 14, 2014 Share Posted December 14, 2014 Or buy my GTR bov! 1 Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7443981 Share on other sites More sharing options...
hardsteppa Posted December 14, 2014 Share Posted December 14, 2014 I tried turbosmart kompact, its way smaller inside than stock bov and gave me turbo flutter. Thought it was shite, snd ditched it, put stock back on. Small hole is 'slight leak' making the on/off of bov smoother but less responsive. Plug it up as scotty says, better from a performance point of view. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444024 Share on other sites More sharing options...
scotty nm35 Posted December 14, 2014 Share Posted December 14, 2014 Smaller inside? Mine doesn't flutter, even on 40 psi. The springs are replaceable, and they come slightly on the tight side from the factory. If your setup flutters slightly you could just ask them for a softer spring. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444031 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 14, 2014 Share Posted December 14, 2014 Stock and unmodified BOV will hold 1 bar no worries. I'm assuming your car is stock, which I believe. Just leave it alone. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444037 Share on other sites More sharing options...
33wishes Posted December 15, 2014 Author Share Posted December 15, 2014 not stock about 400hp @wls , I was getting a whistle noise on full boost.like a leak. I since have blocked the mentioned whole , and now whistle is gone, but bov now sounds different. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444690 Share on other sites More sharing options...
Trex Posted December 15, 2014 Share Posted December 15, 2014 But plugged my hole. Best thing for boost. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444752 Share on other sites More sharing options...
RBrennan25 Posted December 15, 2014 Share Posted December 15, 2014 not stock about 400hp @wls , I was getting a whistle noise on full boost.like a leak. I since have blocked the mentioned whole , and now whistle is gone, but bov now sounds different.I'm actually getting the same thing, any chance of getting a photo of the aforementioned hole? Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444821 Share on other sites More sharing options...
Ben C34 Posted December 15, 2014 Share Posted December 15, 2014 I'm actually getting the same thing, any chance of getting a photo of the aforementioned hole? Take off your bov. Look at it. If you can't see the hole give up on everything. You can't block.the hole with the bov on the car. As the hole is a little larger than m5 tapping size you can simply cut slots in a bolt to make a tap if you don't have a tap handy. Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444853 Share on other sites More sharing options...
hardsteppa Posted December 15, 2014 Share Posted December 15, 2014 I just used a selftapping roofing screw, they have a reallly flat head too so sits flush in the limited space there Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444867 Share on other sites More sharing options...
Blackkers Posted December 15, 2014 Share Posted December 15, 2014 (edited) Oh look this thread again. GTR bobs are a good option too. People have run 25+ psi no issues Edited December 15, 2014 by Blackkers Link to comment https://www.sau.com.au/forums/topic/451747-r33-bov/#findComment-7444879 Share on other sites More sharing options...
