Bosch Ev14. Aeroflow Rail. Freddy Ffp. I Could Butcher This
Ruthr33
 Share
Hey. Got my parts. I can vision leaks thow.
They look nice
This green oring at injector nossle seems .5mm od too small but I could see it seating good when I bolt rail on putting pressure on it
The oring on the boss/adaptor seems to fat to fit into manifold, the adaptor fits snug. So Mabey a thinner oring will Winn this.
This blue oring fits squeaky tight into the rail, just how you would like it. Although, can u see the flange head looking bit on top of the injector? I can see that bottoming out on the injector rail cavity and not allowing the oring to be squashed under pressure. Although the plus side is injector would sit square to the rail. Is this right?
I was thinking Mabey grind the flange off or drill the hole In the rail bigger. Or Mabey that's the way it's spose to be?
Remember there is no pressure really on the manifold o-ring so it doesnt need to be a super tight seal, the top o-ring holds the pressure so this is much more important to get sealed right. It should be reasonably tight in the rail.
My kit all seems normal. Adapters into the manifold are tightish and everything else feels good
The manifold adapters look ok. When the injector is pushed into the adapter it will seal down the bottom where the chamfer is
  • 1 year later...
Bit of a thread dig, but interested to see what people have found, or let people know of a potential issue......
So the manifold adpaters did fit fine in the standard manifold. However, my Greddy copy Manifold was a different story. the adapters are too large and won't fit inside the holes. My plan is to machine them down and use them, just interested to see if anyone else has found the same problem and how they got around it
BPP who supplied my fuel rail said its a known issue with the copy manifolds because they are never made exactly the same. So hopefully a bit of handy info for someone that will be in the same position
Shouldn't be too hard to machine down Callan, sorry I couldn't supply something that works.
I did know the Freddy manifolds are different, but they were larger from my experience, I just supplied a larger Oring for the adapter. Seems yours is smaller so as you say, quality control is shite on those Chinese plenums.
Not a problem mate, I appreciate your time anyway.
As long as Dad had a small enough bit to cut the o-ring grove a bit deeper, I'm not expecting any issues at all.
Its the first issue I've ever had with this manifold, I got it as part payment for some wheels I sold so at least I didn't pay for it[emoji14]
Have had one or two people say it is one of the better copies they have seen so can't be too bad
Ill let you know what size the holes are when I'm home on Friday/Saturday if your interested Scott? I was away so they just got a rough measurement by someone else the other day who didn't have verniers
They standard seals don't have to be forced in so I'm guessing there won't be much in it
Yep, I would appreciate it. These little changes can really cause problems with a top feed install. It should only be the larger part that needs .1mm removed, the Oring grove should be ok, you might just need a thinner Oring. Let me know if you have issues.
For those of you playing at home, measurements were as follows:
Manifold holes: 24.94mm
OD of injector adapters: 25.4mm
Must be made for a 25.5mm hole or so. I got the adapters machined down to 24.8mm and they worked a treat. Just had to try a different o-ring. Photo attatched:
  • Like 1
 Share
    • Any chance the zero demand ignition table is messed up? Or possibly the minimum tps for it to engage zero demand?
    • 32010-AA520 - R34 RB25DET manual transmission, you can buy this new. You'll need a pull to push type clutch converter (to use R33 clutch kits), or buy pull-type clutch (R34 clutch).   R33 part number if you're lazy: 32010-21U00     Applies: RB25DET.MT.F5; Notes: FS5R30A
    • Hi All, Ive recently pulled my head in and gotten started on my 2year long project for my R32 RB25 swap, I went into it head high and confident it was an easy swap and plug and play wiring. I was wrong. The engine is a S1 RB25 and I'm running RB25 ECU And loom. I got the swap done a few weeks ago and have been working on the car on my time off, however i cannot get the engine to run, at first the engine would crank however the fuel pump would not run,  i dove a little deeper and realised that i would need to connect the wires from the RB25 Body Loom and the RB20 Body loom. went through the ECU pinout and followed the wires from the Body looms one by one to find what was needed to start the car. Now I have rewired the RB25 loom with the old R32 Body loom attached, however i am still having issues starting the car, now the pump works but still wont fire.  The car has spark but looks very weak, however I'm suspect that its not getting any fuel. I have read a few posts related to the "Main plug" near the air intake however cannot find any information on what wiring to hook up to where.  If anyone has done this swap, or has any knowledge at all on RB25's into 32 i would really appreciate your comment regarding this, im really keen to get this car finished.  Thanks in advance
